1/0 sufficent? - Car Audio Classifieds!
Old 12-11-2011, 05:43 PM
treylittlefield's Avatar
0/11 sssss5201
Feedback Score: 37 reviews
Default 1/0 sufficent?
i have 2 300 amp alts. had a 4/0 run per alt before the teardown. hard as ehck to run and didnt like how it was done. would good 1/0 (Knu flex, Monster, shok, good OFC wire) be enough? heard that the more strands the better. or would i be better off running 3/0 or 4/0? multiple runs are NOT an option as the space behind the alt is very limited, and if i do 2 runs per alt of 1/0 might as well do 4/0 bc of the price and space. any suggestions? really jsut want to know if 1/0 will carry 300 amps easily over say 20ft..thanks
2000 2dr Blazer
Old 12-11-2011, 05:50 PM
0/11 ssssss855
if multiple runs arent a option then a 3/0 would be ideal 4/0 even better being you have over 600 amps at the alt even if your current draw is only 300 amps.. try looking at welding cable ofc i solder some 3/0 lugs the other day dam things are just big..
Old 12-11-2011, 05:51 PM
0/11 sssssss22
What I would do is a short run from each alt to your front battery. Then make some buss bars and do multiple runs of 1/0. One run will not be enough. Imo
Old 12-11-2011, 05:52 PM
0/11 sssss5201
Battery bank is in the back. This is for my 16v charging system. I have 3 alts. Other one is for truck on 12v.
Sent from my C771 using Tapatalk
2000 2dr Blazer
Old 12-11-2011, 05:54 PM
0/11 sssss5201
It would be a run for each alt. Or could I do a single run of 4/0, and run a jumper between alts? that would be great lol
2000 2dr Blazer
Old 12-11-2011, 05:57 PM
0/11 sssssss22
Oh I see..guess my idea wouldn't work then.
Old 12-11-2011, 06:00 PM
0/11 ssssss227
just a thought? why not like one short run of 1/0 or 2/0 from each alt to a distrobution block where u run like 3/0 or 4/0 to the battery bank? idk, just a thought?
Old 12-12-2011, 09:53 AM
0/11 sssss5201
thinking about running a short 4/0 piece from one alt to another, then run another 4/0 to the battery.
2000 2dr Blazer
Old 12-13-2011, 11:01 AM
Loudforce Distributor.
0/11 ssssss535
I like this option
Old 12-13-2011, 11:11 AM
0/11 sssss5201
Originally Posted by fecupe2001 View Post
I like this option
Just don't know if it'll be enough...
2000 2dr Blazer
what battery is sufficent mrtopnotch561 General Car Audio Discussion & Questions 7 10-25-2011 07:56 AM
