Alt or Batteries? - Car Audio Classifieds!
Old 12-12-2011, 12:49 AM
0/11 ssssss639
Default Alt or Batteries?
I just ordered an SAZ 2k for my sub stage. I do eventually want to get a nice 4 channel. My question is : could I get away with just some beefy batteries? I was thinking the biggest possible up front and maybe something small under a seat or in the trunk.
Could I do that? Or would a nice alternator be more in order.
Sent from my DROIDX using Tapatalk
Old 12-12-2011, 12:53 AM
andrewtexas123's Avatar
0/11 sssss1840
Feedback Score: 17 reviews
With 2k and a 4ch amp you sould be able to do a nice battery up front and something decent in the back, make sure you run 0 gauge and do the big 3 and you will be fine!
The Following 2 Users Say Thank You to andrewtexas123 For This Useful Post:
CousinVin (12-12-2011), cu0ngsayz (12-12-2011)
Old 12-12-2011, 12:57 AM
0/11 sssssss55
I was thinking about the same thing..
Old 12-12-2011, 07:37 AM
0/11 ssssss639
I've got the big 3 done with 0 gauge, and plan on doing a few more runs of better wire to the back of 0. thank you.
Old 12-12-2011, 07:45 AM
jhg33k's Avatar
n00b looking to learn...
0/11 sssss1531
Feedback Score: 31 reviews
Here's the thing about alts and batteries. Batteries store power but can't make them. What good are 10 batteries if there is no way of charging them? I say do alt first and then batts...that's the way I went based on my logic...
If you're only going to run one batt in the back then I'd say you're probably fine with just a batt but if you add more you'll want to beef up the charging portion of the electrical...
|2011 Toyota Carolla S |2 Mmats HD4000.1's | Pair DC XL 12's w/AR cones | Average headrest score out of the trunk...will update after world finals
Old 12-12-2011, 11:14 AM
0/11 ssssss639
Well the way I always looked at it is the batteries are a bank for the power. If there isn't a large enough bank, the system will begin to pull straight from the alt which is bad.
Old 12-12-2011, 11:19 AM
jhg33k's Avatar
0/11 sssss1531
This is true but again, once that bank is depleted what is going to charge it back up? Most stock alt's only give maybe 20-30 extra amps outside of what the vehicle needs...that's not going to charge a batt bank very efficiently
I guess there's always the option of a trickle charger if you'd want to remove the bank after draining them (not going to do much good when you're not at home) but I'd rather just get the alt lol!
Old 12-12-2011, 01:26 PM
0/11 ssssss639
Yeah. But every alt company charges so much. Are any alt brands that are cheaper any good, like irragi?
Old 12-12-2011, 01:28 PM
JMoney18's Avatar
0/11 sssss1577
excessive amperage.
Old 12-12-2011, 01:32 PM
0/11 sssss1840
Its not like hes running a 4-5k system and trying to power it off of a big battery bank.. I have seen many people do a 2k system off a nice XS power battery up front with 0 gauge all around and not having any problems. It is also very common to have people running 2 batteries off a stock alternator with out problems. This topic has been disccused so many times do a little serch if you want more info!
What car is it ill look up what the stock alternator puts out?
Someone around san diego to help install alt and batteries? Ryan1126 General Car Audio Discussion & Questions 0 12-05-2011 01:02 PM
Batteries or HO alt? JMoney18 General Car Audio Discussion & Questions 8 11-06-2011 08:21 PM
Larger ALT or more Batteries ampaddiction General Car Audio Discussion & Questions 9 04-29-2011 09:12 PM
Batteries and Alt for my new system LowLyfe General Car Audio Discussion & Questions 1 01-31-2011 10:25 PM
WTB some batteries or an HO ALT iKidwell Wanting to Buy (WTB) 8 01-10-2011 06:56 PM
