Multiple runs of 1/0. Where? - Car Audio Classifieds!
Old 12-12-2011, 09:49 PM
0/11 ssssss639
Default Multiple runs of 1/0. Where?
I want to do 2 runs of pos and 1 run of neg to my trunk to a second battery, but I am wondering how you guys do this. Would it make sense to run it under the car? I know there is a place i can run it into the trunk, but fastening it along the way is the issue.
How do you guys fasten your wire under your car?
Or should i just balls up and cut a larger hole?
Old 12-12-2011, 10:04 PM
0/11 ssss31255
I run anything over 4 gauge under the vehicle if possible. It's easier.
as for how to do it, you can usually secure the first run with P clips [conduit hanging clips] then zip tie the other lines to the first line.
P clip
Old 12-12-2011, 10:10 PM
nicholask1993's Avatar
Dubstep Addict
0/11 sssss1802
I'd running It under the car get some PVC pipe big enough to fit all the runs and drill some holes an use heavy duty zip ties and screws to secure it to chassis with wore inside...
1998 Subaru Forester
Sony CDX GT-565UP Head Unit
Cadence 6.5" Components
MB Quart Onyx 1500.1
/Surreal
Old 12-12-2011, 10:30 PM
tacomaguy1's Avatar
0/11 sssss4401
I've had 4 runs under my truck for a couple years with no problems...use some big heavy duty zipties and it's good to go.
The pvc would be nice, but not needed
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 12-12-2011, 10:47 PM
jhg33k's Avatar
n00b looking to learn...
0/11 sssss1531
Feedback Score: 31 reviews
I run under my truck as well...just avoid moving parts like the plague and zip tie the chit out of it! We have nasty winters up here in NW Pa and they salt the roads like my uncle does his chicken...no issues with it corroding or anything like that. In my truck I was pretty lucky...there is a HUGE grommet that comes inside from the rear tail lights that I was able to cut open and have a nice entry into the cabin. So far I have two power going out the drivers side light opening and two grounds going out the passenger side light, and it drops right behind the rear bumper cover to the frame
|2011 Toyota Carolla S |2 Mmats HD4000.1's | Pair DC XL 12's w/AR cones | Average headrest score out of the trunk...will update after world finals
Old 12-12-2011, 10:48 PM
0/11 ssss31255
Anyone who says to "use PVC" hasn't done it themselves.
I have used flexible blue plastic conduit for a single run but I wouldn't consider it for multiples because you are limited as far as space and conduit of any kind makes you take up more space.
Old 12-12-2011, 10:50 PM
0/11 ssss31255
schweet
Old 12-12-2011, 10:52 PM
jhg33k's Avatar
0/11 sssss1531
Originally Posted by iamsonic View Post
schweet
Kinda what I thought...I was pleasantly surprised when I pulled the 'ol 4 gauge I started with and started looking for an entry point...I almost fapped immediately!
Old 12-12-2011, 10:54 PM
tacomaguy1's Avatar
0/11 sssss4401
I got lucky too....there's 2 grommets right under my seat on the floorboard, fits 4 runs easily in one, with the stock wiring
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 12-12-2011, 10:59 PM
mcmuffin's Avatar
0/11 sssss3380
i run under my truck 4 runs into my toolbox. i drilled a huge hole. idgaf
*** NEW BUILD COMING SOON ***
its a secret for now
Multiple runs of 1/0ga through the firewall/Where? gibsonm21 General Car Audio Discussion & Questions 3 04-07-2011 06:43 PM
Batt terminals for multiple runs of 1/0 LowLyfe General Car Audio Discussion & Questions 1 03-02-2011 12:40 AM
purpose of multiple runs of wire? poundstone General Car Audio Discussion & Questions 36 01-25-2011 10:30 PM
Fusing multiple runs of 2/0 Cashdollar2009 General Car Audio Discussion & Questions 6 08-23-2010 01:13 PM
Multiple Amps LoudAssblazer General Car Audio Discussion & Questions 13 06-15-2009 12:53 AM
