Do I need a batt or alt ? HELPPPPPP - Car Audio Classifieds!
Old 12-13-2011, 12:52 AM
0/11 sssssss89
Default Do I need a batt or alt ? HELPPPPPP
Ok I'm not a expert at this so don't kil me ha, well I had 4 gauge running from my batt to a distribution block then to 2 dd m1's , the fuse between the battery and distribution block kept melting and the wire slightly burning, so I got a deal on some knu 0 gauge and ran that to the distribution block with 4 gauge to the amps and 4 gauge as grounds , the fuse ain't melting anymore , wires not getting hot , grounds are good , it worked good for like two days , noticed the power diff, but now my lights are dimming bad , headlights even shut off ? What do you think will help ? Never happens with the 4 gauge or any other systems I've had
Old 12-13-2011, 01:00 AM
0/11 ssssss855
becuase befor your current draw was more then the 4 gauge could handle you stepped up to zero so now your system pulls more amps try doing the big 3 as a first if that doesnt help then add a extra battery in the back (after the big 3 ) if you still have a pretty bad voltage drop then you need a high output alternator make sure your gains are set correctly because clipping could use more power then clean signals ..
Old 12-13-2011, 01:06 AM
0/11 sssssss89
With the big 3? You replace the battery ground ? Alternator ground ? And alternator to Batt? , do you know how much feet of 0 gauge you used to do it ? Trying to get the whole picture , I'm not a pro , is it hard to do ? Usually don't trust shops in my area as there prices are crazy high so I do most on my own ?
Old 12-13-2011, 01:52 AM
ninos's Avatar
0/11 sssss2421
depends what car u have bro
Old 12-13-2011, 01:57 AM
Kingdom of Solitude
0/11 sssss1254
Do the big 3 and report back with your findings.
Youtube Channel
Old 12-13-2011, 02:23 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
What car do you have?
Triple and quadrouple check your connections.
Do the big 3.
Get voltage readings.
Team CACO Team SHOK
Supporting Member
Old 12-13-2011, 04:01 AM
0/11 sssssss89
I have a 2000 dodge ram , connections all look good , I don't know how to do the big 3? Any help ? How much wire ?
Old 12-13-2011, 04:06 AM
0/11 ssssss227
it depends, i dont know how much wire for u, but i used like 6 feet or so? (i drive a cavalier lol) bur u run one wire (1/0 or bigger is usually recommended) from ur alternator to the positive on ur battery, then one from the negative on ur battery to ur frame then another ground from ur battery to your engine block. hope this helps (i am no pro lol but thats how i did mine)
Old 12-13-2011, 06:00 AM
newarkbeast973's Avatar
0/11 sssss7810
Also, you don't replace the battery's ground. Just add on to it. The more wire the better. You'll be surprised the gain you get from this. I say get 10' of 1/0 and some type of wire loom or techflex just to dress it up a bit and to protect the wire from extreme heat from the engine.
New build coming soon!!
Old 12-13-2011, 07:17 AM
mtrevino92's Avatar
0/11 sssss1526
Feedback Score: 21 reviews
Check this out: BIG 3 Upgrade for 96 Dodge Ram - YouTube. You can search youtube for more.
batt vs alt thel.t.d.supply General Car Audio Discussion & Questions 22 03-07-2011 08:24 PM
alt and batt power basshead08 General Car Audio Discussion & Questions 11 01-26-2011 09:45 AM
some opinions on batt/alt.. Dunbar91 General Car Audio Discussion & Questions 5 06-06-2010 01:11 PM
More batt or h/o alt? bassman_soundking General Car Audio Discussion & Questions 43 09-22-2009 09:44 PM
alt or batt? Snwbrdr1 General Car Audio Discussion & Questions 20 03-17-2009 09:18 PM
