car audio help - Car Audio Classifieds!
Old 12-13-2011, 07:13 PM
0/11 ssssss176
Default car audio help
i recently got some zero gauge wire ran in my tahoe, and a yellowtop optima battery up front.. i put in 2 sundown sa 12's in a ported box tuned to 36 hz on a saz 2500.. my voltage drops to around 10 volts when i have it running full tilt when cranked.. would there be a very noticeable difference if i had a stable voltage? Whats the best way to do it? 2 batteries in the back? Thanks for the help!
Old 12-13-2011, 07:15 PM
Super Moderators
0/11 sssss9623
that amps gonna be gone very soon ... get an alt... you have a truck that every major alt company makes and alt for... BUY ONE!
Old 12-13-2011, 07:28 PM
chapdawg1971's Avatar
Semi-Loud Trunk
0/11 sssss1950
Feedback Score: 25 reviews
I'd add an additional battery first, do the Big 3 and THEN see where your voltage is.
That is very low on what you have. It could be other issues.
I am here: Google Maps
Sent from my iPhone 4S using Tapatalk
4th USACI WF 2011 Trunk 0-1K 154.3db
157.??....and done.
Old 12-13-2011, 07:39 PM
little-kid-wit-bass's Avatar
0/11 sssssss70
You might need to recharge your battery under the hood because i know that amp has already sucked some power away from it. Do like said and do the big three add a 2nd battery, then see if you get a better voltage. Or if you can afford an alternator right now, go ahead an get an alternator.
Team BangGang
Old 12-13-2011, 07:40 PM
GoodyearJason's Avatar
0/11 sssss1398
Big 3, Alt, and a battery. 2500 watts is enough power to require all 3. And make sure you don't skimp on connectors
Kenwood KVT-514, Clarion EQS746, Singer Alts, Ampere Audio amps
Old 12-13-2011, 07:42 PM
logan23afroman's Avatar
0/11 sssss1813
Feedback Score: 30 reviews
solid grounds, good wire, and buy a 200 or higher alt!!!
"Loudest Jeep Commander"
4xSundown sa-8''s
aq1200 with dual 0 gauge inputs!
141.6 on dash at 48hz with 594 clamped watts
Old 12-13-2011, 07:52 PM
0/11 ssssss176
thanks guys! What kind of additional battery would be sufficient in the back after big 3 for now?
Old 12-13-2011, 08:31 PM
0/11 sssssss70
Xs power. They make great batteries.
Team BangGang
Old 12-13-2011, 08:50 PM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
Kinetik, Shuriken, Deka, XS depends on ur budget. XS in general r the best but r expensive, Kinetiks r just below those. Deka's r mosters and can sometimes be bought cheaper because they r intended for car audio so they dont charge a crapload for em
2005 Buick LaCrosse
HU: Alpine INE-S920HD
Old 12-13-2011, 09:41 PM
0/11 ssssss176
was also told that i should upgrade to 2 more 12's or go bigger in subs because of the room i have to work with..? What's something in my power range if i upgraded my alt and batteries and had all the power from the sundown amp? What subs should i go with? I like the sundown sa 12's but want louder.
WTS/WTT Lots of Car Audio for other car audio extreme Car Audio Trader (WTT) 2 12-15-2010 07:04 PM
Re: What car audio brands you got in your car? andrew198501 Recycle Bin 0 08-11-2008 08:34 PM
Re: What car audio brands you got in your car? mhart Recycle Bin 0 08-11-2008 08:28 PM
