bass processor questions ( hifonixs bxi pro 2.0 ) - Car Audio Classifieds!
Old 12-13-2011, 10:32 PM
0/11 sssss1406
Default bass processor questions ( hifonixs bxi pro 2.0 )
I was thinking bout getting a hifonics bxi pro 2.0 for my subs and i have a few questions, and from what i can see it says PMF SUBSONIC FILTER 35hz is the lowest it goes, does that mean it wont play under 35hz? And even if its just a center point would that even help me if my box is tuned to 30hz? Help me b4 i make a bad choice and buy something that wont work for me.
Old 12-17-2011, 02:59 AM
0/11 sssss1406
Bump please
Old 12-23-2011, 11:16 PM
0/11 sssss1406
Bump please
Old 12-24-2011, 07:04 AM
duro78's Avatar
0/11 ssssss386
put your money in a dsp to control all your ranges. Bass expanders are a waste of money
Head unit-cda 9887/ dsp-jbl ms8 /Amps- 2 ppi p900.4
/tweet- lpg26na /mids-tang band w3 /mid bass-dayton rs180/subs- 2 10w6v2
Old 12-24-2011, 07:46 AM
DreDay256's Avatar
1SikMag
0/11 ssssss319
I agree. Look at AudioControl for a good processor.
Old 12-24-2011, 11:04 AM
duro78's Avatar
0/11 ssssss386
Like he said audio control has excellent products. Stay away from the cheap stuff get it right the first time and at least it will have some kind of value if you want to sell it
Sent from my DROIDX using Tapatalk
Old 12-24-2011, 11:25 AM
0/11 sssss1406
what is a dsp and what all do they do?
Old 12-24-2011, 11:49 AM
duro78's Avatar
0/11 ssssss386
Digital sound processor. Pre amp signal processor which allows u to tweak your crossover and adjust your eq depending on the model you pick. Checkout their website audiocontrol.com
Old 12-24-2011, 11:55 AM
0/11 sssss1406
ok i checked them out and im seeing that theres only a "sub in" and "main in" i dont see how that will work when i have a 4 channel amp and a sub amp. im so confused!
Old 12-26-2011, 02:47 AM
gibsonm21's Avatar
0/11 ssssss392
what exactly are you trying to accomplish? Does your sub amp not have a lp and subsonic/hp filter?
"WHEN you're thinking of replacing a blown fuse with a higher rated fuse ask yourself if you know more than the engineer who designed the equipment."
soundstream bx 10 bass processor line driver pre volt booster xmikedxl Head Units, Processors & EQs 9 12-13-2011 07:17 PM
AQ pro audio questions / advice burzendowski General Car Audio Discussion & Questions 11 09-24-2011 09:49 AM
(SOLD) BNIB Soundstream BX-12 Bass Processor spencerearl1996 Head Units, Processors & EQs 19 02-02-2011 06:56 AM
Soundstream sound processor and bass processor? Russellabt General Car Audio Discussion & Questions 5 12-01-2010 02:03 PM
Clarion pro dsp910 processor civicman07 Head Units, Processors & EQs 23 04-16-2009 03:06 PM
