big 3 stock alt question? help is appreciated - Car Audio Classifieds!
Old 12-13-2011, 11:52 PM
thel.t.d.supply's Avatar
0/11 ssssss835
Default big 3 stock alt question? help is appreciated
i have a 1998 isuzu rodeo v6 4x4. i am wanting to do the big three and add an extra batt. i would also like to add ho alt later.
the problem... basically under the hood there is a seperate fuse box and all the wires for the alt run from a plastic wire harness clip to the fuse box and then to the battery. can this be bypassed or what?
i see no way to do the big 3 in 0awg... maybe the big one lol.
not to mention this is the first big 3 install i have done.
i can take some pics soon if it helps.
new build old equipment
Old 12-13-2011, 11:53 PM
Pieper's Avatar
Winston Churchill > You
0/11 sssss9716
Feedback Score: 84 reviews
When you do the big 3, you don't need to replace the stock wiring. You just supplement. So leave the stock wiring alone and add your own.
Old 12-14-2011, 12:00 AM
0/11 ssssss835
well i do understand to add to not replace but i was concerned bypassing the fusebox and adding directly from alt to batt.
also i can't add to the wire harness that clips to the alt.
Old 12-14-2011, 12:03 AM
Pieper's Avatar
0/11 sssss9716
This part confuses me. Like you said throw some pics up. Bypassing the fuse box shouldn't be an issue though.
Old 12-14-2011, 12:26 AM
0/11 ssssss835
well black whole with the prong sticking out is where the clip goes i will take pic tomorrow in light
Old 12-14-2011, 01:35 AM
You don't do anything to the part that clips into the alternator. The wire you upgrade goes from the threaded post (right next to the clip) to the battery + terminal.
thel.t.d.supply (12-14-2011)
BIG 3: Alt. to Battery Question EARmeBump General Car Audio Discussion & Questions 9 09-04-2011 02:34 PM
How much does my stock alt put out? thisistiny General Car Audio Discussion & Questions 7 06-23-2011 12:25 PM
Stock 140a Alt for GM 3800 Series II or a cheap HO alt Raptor660 Wanting to Buy (WTB) 10 04-08-2011 08:11 PM
[NLFT] Blazer 200 amp H.O. Alt- trade me your stock blazer alt Bushj311 Wiring, Electrical & Other Installation Equipment 52 05-19-2010 12:59 PM
How many watts on stock alt? BlueLude General Car Audio Discussion & Questions 23 09-20-2009 09:13 PM
