Amp goes into protection on front stage - Car Audio Classifieds!
Old 01-12-2012, 06:36 PM
infaredsinsor's Avatar
0/11 ssssss769
Default Amp goes into protection on front stage
The amp is grounded WELL, my voltmeter is not going below 12, battery is good, gain is not to high, and the ohm load is at 2 ohms. I turn on the head unit and sometimes it plays for 10min before deciding to go into protect. Other times, it is on for 30 seconds and goes into protect. I thought it was only at high volume that was causing the problems, but that isn't it. It is like an intermittent failure and happens when it wants. I know there is a logical explanation out there. Has anyone experienced this? Please help!
Could it be a low voltage drop in the remote wire?
It's a Soundstream Rub500.4
Subs, amps, and power
AFEX Fire Suppression Systems Quality Engineer
itrader info available on profile
Old 01-12-2012, 06:38 PM
Prohibited Sellers/Buyers
0/11 sssss1770
do u have any dc voltage on the rca jacks?
Old 01-12-2012, 09:01 PM
0/11 sssss2429
Feedback Score: 46 reviews
Wire the front to the back channels, does it follow? Swap rca's
Sent from my Punch 60.2
Old 01-12-2012, 11:14 PM
0/11 ssssss769
I will have to check. I just ran a new pair of i306 Monster 4ch the other week and everything has been fine. It's like it grew and attitude,lol. I want to pull my hair sometimes when sh*t like this happens. That's the nature of the beast I guess.
Old 01-13-2012, 01:46 AM
0/11 sssss2429
Just try to eliminate one thing at a time or it will just confuse things more.
Swap RCA location at the amp first, front to rear, rear to front. Did it follow,yes hu to amp issue. No, amp to speaker issue. Eliminate the amp by swapping speaker wiring, front to rear. You get the idea, divide the system with yes or no questions to eliminate pieces at time. You have other factors like a crossover maybe, but try to factor it out.
Old 01-13-2012, 01:52 AM
0/11 ssssss769
I will try that. I have been eliminating all the basics first. I know that the Front and rear are hooked up correctly because the fade still work through the HU. I also know that the speakers are hooked up right because I used different color wire with each to keep them straight. I am going to disconnect one set at a time to see if one is causing a short to ground problem.
Old 01-15-2012, 08:57 AM
0/11 ssssss769
I am reopening this topic. Okay, so I have narrowed it down to the amp only goes into protect with the RCA's connected. I have a Clarion VX400 and the amp is a Soundstream RUB500.4. It will play fine at low volume for a short period of time, but when I crank the volume, it goes into protect. I recently tapped a voltmeter into the ground, power, and ACC line behind the HU. Would that have anything to do with it? I also have read that the preout voltage from the HU may be bad or there could be an issue inside of the amp. Can someone please shed some light on this or pass down some key troubleshooting techniques? I am at my whits end here!
Old 01-15-2012, 09:20 AM
0/11 sssss2429
Check the preout with your dmm (AC volts) on the rca wires going to the amp. How many rca cables do you have running, one set for front, one set for rear? If you remove the front set and crank it will it go into proect, Yes issue with the rear setup. NO issue with front. Remove rear set and insert front crank volume, will it go into protect? Yes definitely something wrong in front, No then it could be amp issue.
When cranking the volume hook your dmm across the speaker output of the amp, do you read any DC volts?
The Following User Says Thank You to brandes.cm For This Useful Post:
infaredsinsor (01-15-2012)
Old 01-15-2012, 09:25 AM
0/11 ssssss769
I am running one set of brand new monster i306 4ch. I have not changed speaker configuration. I have Infinity components in the front and Infinity 6X9's in the rear. I will have to do the dmm testing this afternoon when the kids go down.
Old 01-15-2012, 12:12 PM
0/11 ssssss769
What if I find DC voltage?
OS Sony XM-2252HK.. Beast Front/Rear Stage Amp! Raptor660 2-Channel Amplifiers 4 01-30-2012 03:06 AM
Added to the front stage Mids&highs IS300IAdeathRow Car Audio Videos 0 05-01-2011 01:17 PM
Front Stage help, Powerbass 8s, or B&C 10s? tez4life General Car Audio Discussion & Questions 6 11-26-2010 11:43 AM
WTB: Front Stage speakers/amp Bobby32 Wanting to Buy (WTB) 5 06-29-2010 06:45 PM
WTS: Don't need this 10 , need cash for front stage amp bad:( splvictim20 10" Subwoofers 1 11-13-2008 12:27 PM
