Is this sub under warranty??? - Car Audio Classifieds!
Old 01-12-2012, 09:35 PM
0/11 ssssss855
Exclamation Is this sub under warranty???
hello all i have a question but not sure what to do.. i will be going to where the sub was made tomorrow but don't want to look wrong in asking for something that wont be covered im not going to say the name of the company because i dont want to give them a bad rep.
so we picked up the sub and it still smelled a bit like super glue but the sub is a monster lol rated at 2500 rms all gains were set with a dd-1
the amp is a t2500bd
the sub coils are 1.7 ohms
well the question is we put the sub in the box and played it on low volume to make sure everything sounded fine for around 2 songs bass mechanic from itunes and it sounded good at low volume then we turned it up but it sounded like it was blown so we pulled it out and checked the coils one reads 1.7 but the other is open is this covered under warranty?? the sub never smoked popped or even smelled just like super glue lol checked the sub out for clipping after we pulled the sub and the signal was clean hes voltage is great a hc1400 and a hc800 and a 200 amp alternator .. ?
Old 01-12-2012, 09:38 PM
0/11 sssss2821
You're in nevada. It's Fi correct? I'm guessing it got clipped badly. Coils generally will not be warrantied, because abuse will cause an open coil. Fi may feel bad for you and hook you up though. Was it new when you hooked it up?
AKA Zachfeen
Team NWSPL
Toy
The Following User Says Thank You to stangman67 For This Useful Post:
lilsoccersully (01-12-2012)
Old 01-12-2012, 09:48 PM
0/11 ssssss855
i checked the signal before anything got hooked up with the dd-1 about 3 times and all the same results and yes dam near fresh like 1 hour from picking it up even check the signal after wards and same results clean
Old 01-12-2012, 10:57 PM
thumper21's Avatar
Blow-thru KING
0/11 sssss1919
If it is Fi, just call Scott. Shit happens and I'm sure if it was user error he would help you out with getting you a recone or replace the sub. Nothing to get embarassed about, subs usually fail one or two ways, either clipped(user error), or improper build(MFG error)
Speed and SQ
The Following User Says Thank You to thumper21 For This Useful Post:
Old 01-12-2012, 11:10 PM
0/11 ssssss855
for sure im going to take the whole car over to him tomarrow as soon as they open and see what he says, Ive installed a system or two and rechecked all the wiring and made sure all things were what they supposed to be, Even after it was acting weird and it all came clean except for the sub but if it was user error then id admit it just do not know where Ill post what happens tomorrow
Old 01-13-2012, 05:14 PM
0/11 ssssss855
well we went to fi in the morning scott was surprised to see use so soon back lol he said the sub looked mint as did the coil so he was going to have one of his guys take the dust cap off and check the leads if its a bad coil (open coil) they were going to recone it under warranty cool guy..said the sub should be ready by 4 pm today
warranty fyerbyrd22 (Crescendo) 1 07-16-2011 04:54 PM
warranty? crownvicon26's General Car Audio Discussion & Questions 9 03-03-2011 02:15 AM
warranty question korey_hofer General Automotive Chat 12 02-10-2011 09:34 PM
Warranty transfer TurdFergueson2 General Car Audio Discussion & Questions 6 09-14-2010 07:09 PM
Warranty voids Tkelly (Crescendo) 16 07-05-2010 05:21 PM
