carputer vs ipad/tablet indash - Car Audio Classifieds!
Old 01-13-2012, 08:51 AM
0/11 sssss1406
Default carputer vs ipad/tablet indash
Whats your guys views on these? Pros and cons on both please
Old 01-13-2012, 09:18 AM
EpicenterDesigns's Avatar
Loyal Member
0/11 sssss1862
I have a little experience with both.
The iPad is removable and can go with you when you reach your destination. You can watch movies and playing music can sound pretty good in some cases.
A carputer is built in. You can still do the movies and music, but usually in larger capacities. A plus is that you can do actual computing. We designed a 4th order box on the way to buy wood last weekend. I am not aware of BBP for iPad.
I think with a little more money, you can get CD quality sound from the carputer.
It is really just preference. I like using the carputer but I also like the flexabilty of the iPad.
The bitter after-taste of a poor quality job will last far longer than
the sweetness of that cheap price!
Old 01-13-2012, 11:19 AM
0/11 sssss1406
Witch one has better sound quality out of the box?
Old 01-14-2012, 08:23 AM
Loyal Member
0/11 sssss1862
Out of the box, the fastest way to connect one to your stereo is the 3.5mm plug.
The carputer would use the headphone out jack to your amp. Downside is low output voltage. We used this for months with no issues other than having high gain setting.
You can buy a better stereo output. And there is software you can download to go active.
The iPad would connect to your stereo the same way. Only you have the options of connecting to your current head unit via the 3.5mm jacks and aux inputs and having a higher output voltage because of the headunit.
Old 01-14-2012, 09:38 AM
0/11 sssss1406
Ok thank you, so the ipad/tablet is probly over all easier. . .
using a tablet as carputer carPC ect.. nicyousuckk General Car Audio Discussion & Questions 20 12-22-2011 08:22 PM
anyone ever try a tablet or ipad as an audio source in there car? HACKMUNCH General Car Audio Discussion & Questions 7 02-01-2011 04:41 PM
