saz 4500 protect problems.... need help! - Car Audio Classifieds!
Old 01-13-2012, 05:20 PM
Tiller's Avatar
0/11 sssss1427
Default saz 4500 protect problems.... need help!
soo installed my 4500 this morning... turn the gain to a third just to see what it would do...
(subs are 4 sa 12's d2 in parallel for 1 ohm nominal)
slammed it for about 10 min. took it home made sure nothing was hot... and start to put things back together to cleanup....
went to go get some food and the first song boom protect!!!
my voltage is good it wasnt dropping below 13.5.... i started playing around with it more and it seems i have to roll into it... but still when i go full tilt it protects...
idk what it could be that would make it do this... i swapped out my 2500 to the 4500 and my 2500 ran like a champ??
please let the comments spill!
"I'm not addicted I'm committed"
Old 01-13-2012, 05:23 PM
0/11 ssssss259
Maybe double check your sub wiring.. also check your grounds maybe... I would always start there good luck.
Old 01-13-2012, 05:25 PM
Tiller's Avatar
0/11 sssss1427
grounds are 100% and soo is the sub wiring... im anal...
Old 01-13-2012, 05:28 PM
DC98hoe's Avatar
Doing 156s below the seat
0/11 sssss1372
I was goin to say blown sub but since it worked with other amp.. probably not... check power and ground connections also check voltage at Amp when its playing an protects
98 tahoe 4-team ascendant 18s ,2-Flatline 9.5s 18 v --singer 320 hairpins-4th order 160dbs
Old 01-13-2012, 05:31 PM
mega fatty
0/11 sssss6008
make 100% sure no wires are touching
check subs with a dmm, maybe one took a digger on you
07 mazdaspeed3
rd d9 @ .5ohm
Tiller's Avatar
0/11 sssss1427
will doo and ill recheck the subs...
Old 01-13-2012, 05:32 PM
Active Member
0/11 ssssss546
You got a warranty right? I would say if you're sure your wiring is good and voltage is holding, contact dbr. I would double check each sub individually just to be certain. Sucks because you waited so long for it and now have to wait again, but at least you will get it fixed properly under warranty.
Tiller's Avatar
0/11 sssss1427
whats a digger?? smoked it you mean?
Old 01-13-2012, 05:33 PM
Tiller's Avatar
0/11 sssss1427
i do have a warranty.... and ever since i opened the box i was scepticle... you can tell it was rushed.... thats all im going to say about that untill im 100% certain its not my fault
Old 01-13-2012, 05:35 PM
caloriu's Avatar
0/11 sssss2863
Feedback Score: 107 reviews
i had a similar issue with a saz 2500 it was a factory defect from a bad batch as soon as i talked to chris at db-r he knew what the problem was. my saz was going into protection radomly even if i turned the car off with the radio on when i statred the car the amp would go into protect all i had to do was turn h.u. off and back on and it was fine . call chris at db-r he might know if your 4500 might have a factory glitch.
i ended up sending mine back to the seller and he sent it to sundown for a repair.
Saz 4500 4x4xfl Craigslist Deals 8 12-06-2011 06:34 PM
Saz - 4500 KZnova Wanting to Buy (WTB) 2 10-09-2011 07:48 AM
Sundown 4500 SAZ-4500 Jokerr Mono Amplifiers 2 08-28-2011 05:05 PM
My Truck - 8 SA-12 and 1 SAZ-4500 at .5 jagblazer01 (Sundown Audio) 6 07-19-2011 08:04 PM
Sundown SAZ 4500 EdgarCervantes Mono Amplifiers 19 05-06-2011 12:12 AM
