HO Alt/voltage question - Car Audio Classifieds!
Old 01-13-2012, 07:51 PM
0/11 ssssss889
Default HO Alt/voltage question
So i am waiting on my Excessive Amperage 250a alt to come in and i had to get the external regulator, but here is my question....What is the maximum voltage i can set it to without frying the pcm/ecu? My 97 Jeep Grand Cherokee limited V8 has the pcm control the voltage so when i get the new alt it will be externally regulated instead. I know some cars can be at like 14.8 and some at like 15.5, but what can i set mine to?
Thanks
Old 01-14-2012, 08:48 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
i have been thinking of sending my alt back to nate and going external as well. my computer only lets me see 14.5 max when cold and 14.2 warm. i wanna set it at 14.7 and keep it there. let me know how your turns out so i can decide what i am going to do.
My game is legit,
Old 01-14-2012, 08:56 AM
0/11 ssssss889
Alright, will do. I'm just worried about frying my ecu/pcm cuz it can only handle so much voltage.
Old 01-14-2012, 11:29 AM
slowpoke's Avatar
newbie forever
0/11 sssss1160
Thanks
jeep had/has in mind with there electrical that most people will likely install wenches and other high demand items. as it was told to me, the eec is 16vdc safe. not to exceed 16vdc. 15.5vdc can be dangerous. if it spikes beyond 16vdc after time it will cause the eec to fail. thats why most systems are set to about 13.5-14vdc. pretty much everything else will run ok to but again keep in mind that more voltage to your lights, fans ext will also cause them to run warmer resulting in decreased life of your components. thats why most people with the higher voltage systems will use step downs to run the systems while allowing the higher voltage to run the audio system.
there are alot of threads all over this forum on voltage in the search engine. i know it can be boring but check some out before you decide to do anything.
Old 01-14-2012, 11:34 AM
0/11 ssssss889
Alright, thank you. I just wasn't sure, i will probably set mine at about 14.3 or so but i just wanted to see if it would be bad to go any higher. Sounds a little dangerous to me to go higher. But thanks and i will definitely search for some.
Low voltage from alt? Jokerr General Car Audio Discussion & Questions 8 07-25-2011 04:19 PM
changing idle voltage on alt 9515ROB General Car Audio Discussion & Questions 1 10-11-2010 09:55 AM
2nd alt will TREMENDOUSLY help voltage drop right? CleanNMean General Car Audio Discussion & Questions 2 10-26-2009 11:44 PM
my voltage w my new alt michael707 General Car Audio Discussion & Questions 7 10-06-2009 04:27 AM
Raising alt voltage the easy way. DLP customs Tutorials & Quick References 0 01-04-2009 12:45 PM
