Opinion wire gauge - Car Audio Classifieds!
Old 01-13-2012, 10:34 PM
0/11 ssssss184
Default Opinion wire gauge
I have a stock alternator at 12.8 volts and currently have 4 ga wire from last system would it be worth it to upgrade to 0 ga wire on stock alt cause ill be running a saz 1500D would it make a difference on 0 ga or no and why if not wat gauge do u suggest ill be using the same gauge suggested to do big three until i upgrade my alt ty for any input
Sent from my SAMSUNG-SGH-I777 using Tapatalk
Old 01-13-2012, 10:36 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
doesnt the saz1500 have 0 gauge inputs? you should always be running the biggest wire you can fit in the amp terminals at least
-Youtube Channel
Old 01-13-2012, 10:38 PM
0/11 ssssss184
But why will it get more voltage or wat. Wat does the zero ga do if it is stock alt
Old 01-13-2012, 11:49 PM
Bologna's Avatar
Ad ministrator
0/11 sssss2872
When you are are higher rpms then it will give it more power. You can never go too big on power wire.
Also you know you will be upgrading down the road, so you might as well buy the wire now lol.
Refs: BlackWaterOp x2, Master69 x3, Scottie x3, RidnClean, JusBlaze (Scammed Me), SPLaudio x3, ltr450racer690, dbeez, LuisT, SPY, Mgcauctions09 x3, pieper88 x3, scottyk, Jh8909, JB312, stretch, Mechman, 01SpyderDB23, andrewtexas123, 50 black guys, bubbagumper6, btr, SacTownBully84
Old 01-14-2012, 12:10 AM
0/11 ssssss139
I apologize for hijacking the thread but I got 2 3000ds and some dual toolmaker 0 gauge inputs. The battery is like >4 feet away from the batts. I was thinking of of running two 4 guage wires with 150 amp fuses. What do you guys think about that?
Old 01-14-2012, 12:24 AM
Bologna's Avatar
Ad ministrator
0/11 sssss2872
I would recommend 1/0 gauge, not 4 gauge
Old 01-14-2012, 12:36 AM
0/11 ssssss139
Going of the wire gauge power chart it says I would be good for up to 180 amps for under 6 feet but I want opinions because I got tons of 4 gauge and I'd have to buy 20+ feet of 0 gauge and I didn't want to waste the money if I didn't have to
Old 01-14-2012, 12:41 AM
Bologna's Avatar
Ad ministrator
0/11 sssss2872
Well then I suppose you could always just run 2 4 gauges along side each other and solder them together in the same ring terminal and make your own 1/0 gauge lol.
Old 01-14-2012, 02:56 AM
0/11 ssssss139
Why would I solder them when I could just run 2 wires to my amp and put 2 ring terminals up on the batteries for each wire?
Old 01-14-2012, 06:02 AM
0/11 ssssss137
100% necessarily. Go with full copper, not the CCA.
wtb 14+ feet of blue monster wire..... must be 0 gauge and 4 0 gauge inline fuse hold steven_escalera Wanting to Buy (WTB) 1 08-19-2011 08:27 AM
0 Gauge/4 Gauge Misc. Wire w/terminals NoPh33rRaCiNg Wiring, Electrical & Other Installation Equipment 7 03-24-2011 01:10 AM
WTB 0 gauge wire and 8 gauge speaker wire seanaspain Wanting to Buy (WTB) 6 09-17-2009 08:27 PM
