another box question - Car Audio Classifieds!
Old 01-14-2012, 11:33 AM
0/11 ssssss259
Default another box question
I have a aq hdc3 15 with copper coils d2 newer style basket its going in my dodge truck in the back seats. I will be running hifonics 2608d at 1 ohm. I know that this amp doesnt do rated power but I know that it should be pushing this sub preaty darn good. On to the question wanted it tune to 35hz. Whats the best placement for the sub and the box for a truck and also since i am putting more than rated power. so I want control from the sub so what size box should i be making. thanks.
Old 01-14-2012, 06:43 PM
sruggles1976's Avatar
0/11 ssssss271
As for the Hifonics not doing rated, I have clamped a few of them including the 2608 and they always did right at rated.
I havent built an extended cab, but alot of them I see is sub forward and port up. 4 cubes net and 64 sq inches of port is recommended. U can stretch it to 4.5 cubes net and 72 sq inches per cube with no issues. u planning a slot port or aeros?
Sub: AQ HDC4 15
Amp: AQ3500D.1
Electrical: Big 3, 2 runs of 1/0 Wire, Dual G31 Yellowtops
Intrepid is 2X National Champ MWSPL Basic Trunk
151.2 db @ 1880 watts clamped on the dash
Old 01-14-2012, 06:51 PM
0/11 ssssss259
I was tthinking 4 cuft with an 8" aero. As of the amps that's nice to know they do rated.... I am just worried if I go any bigger the sub will not have any control with that much power
Old 01-14-2012, 07:03 PM
0/11 ssssss259
I seen your setup on utube holly crap I think u had a 12 aero with one hdc4. 15 how did that sound peaky?
Old 01-14-2012, 08:02 PM
0/11 ssssss271
Should sound good man. I wouldnt go any bigger on the box or smaller on the port. 12.5 sq inches PER CUBE is on the smallish side but its an aero so it will be more efficient than a slot.
Sub: AQ HDC4 15
Amp: AQ3500D.1
Old 01-14-2012, 08:07 PM
0/11 ssssss259
^^^^^^ how do you fiqure out area for aeros again
Old 01-14-2012, 08:08 PM
0/11 ssssss271
LOL.. yeah just a little That was actually my burp box. It was designed to use with the HDC3 and peak out at 2000 watts at around 52-53 hz. That sub you saw was a prototype and that particular spider/surround wasnt nearly as effiecient as the production model.
Now that 12 inch port is PERFECT for a 6.5 cube net 18 box, and we will be tuning one in tomorrow with that setup. Hopefully Ill get some vids.
Sub: AQ HDC4 15
Amp: AQ3500D.1
Old 01-14-2012, 08:09 PM
0/11 ssssss271
Pie (3.14) x radius^2
So for the 8 inch aero, its: 3.14 x 4 x 4 = 50.24 sq inches
50 sq inches / 4 cubes = 12.5 sq inches per cube.
Sorry I mistyped on that original post about port ratio.
Sub: AQ HDC4 15
Amp: AQ3500D.1
oa-12 box question/help skartisu General Car Audio Discussion & Questions 3 10-29-2011 12:48 AM
Box Question. RE box calculator ianlahood13 Enclosure Discussion & Design Construction Help 1 06-06-2011 12:23 AM
Sub Box question. I r box nub. MisterTedster General Car Audio Discussion & Questions 2 10-03-2010 09:32 PM
box question kingmade08 Enclosure Discussion & Design Construction Help 6 09-06-2010 10:09 PM
box question (NOT A DESIGN QUESTION) highpsicobra General Car Audio Discussion & Questions 0 07-15-2010 02:10 AM
