Amp repair help - Car Audio Classifieds!
Old 01-14-2012, 12:50 PM
mega fatty
0/11 sssss6008
Default Amp repair help
I have a blown pa p600.5s
Goes into protect right away
I found 4 blown diodes with no part number so if anyone has a idea on these feel free to chime in
Also I found 4 shorted fets
Along with a shorted gate resister and possibly a shorted gate fet.
The two larger fets in the drive read 34ohms across the gate, I'm just not sure if it's the blown resister showing this though would it be smart to just replace them or should they be ok?
Any help would be appreciated
07 mazdaspeed3
rd d9 @ .5ohm
Old 01-14-2012, 01:36 PM
Prohibited Sellers/Buyers
0/11 sssss1770
what the name of the amp? and u have a picture of the whole amp?
Old 01-14-2012, 01:51 PM
mega fatty
0/11 sssss6008
The amp is a planet audio p600.5s
Also I chose the right 2 blown fets and cut them out, so the MOSFET on the gate, the gate resister and the other 2 fets check out now, so it was 1 of each of the fets on the sub channel.
I'm still stumped on the diodes though
07 mazdaspeed3
rd d9 @ .5ohm
Old 01-14-2012, 02:00 PM
mega fatty
0/11 sssss6008
actually i think i found the diode
it was super faded but i think it says Fmg22R, although that part number isnt on mouser or digikey
another breakthrough!!!!
one pair is a Fmg22r and one pair is a Fmg22S
07 mazdaspeed3
rd d9 @ .5ohm
Old 01-14-2012, 02:08 PM
0/11 sssss1770
does it pull a lot of current when its on?
Old 01-14-2012, 02:11 PM
mega fatty
0/11 sssss6008
idk only time i ever powered it on was on a 50A power supply, i got it from a friend blown and its been sitting for a while, through my work i have been learning alot about fets and diodes and such and thought today would be a good lazy day to tackle the project.
im not so sure the diodes are bad anymore. the outer leads read dead short, but they are insulated from the middle (about 100kohm from each side)
idk this diode is different from the ones im used to.
07 mazdaspeed3
rd d9 @ .5ohm
Old 01-14-2012, 02:15 PM
0/11 sssss1770
most likely those are good. check the transistors in the power supply.
Old 01-14-2012, 02:21 PM
mega fatty
0/11 sssss6008
all the power supply transistor check out
07 mazdaspeed3
rd d9 @ .5ohm
Old 01-14-2012, 02:25 PM
0/11 sssss1770
take all the output transistors out and try to power it up.
Old 01-14-2012, 02:27 PM
mega fatty
0/11 sssss6008
even the ones on the 4 channel portion?
07 mazdaspeed3
rd d9 @ .5ohm
Amp Repair Kyle K General Car Audio Discussion & Questions 8 05-31-2010 12:06 PM
Amp repair??? Dunbar91 General Car Audio Discussion & Questions 2 05-08-2010 05:09 PM
amp repair slammed636 (db-r) 2 10-26-2009 11:14 PM
Amp repair? SPY General Car Audio Discussion & Questions 18 03-29-2009 09:49 AM
