Bigger motor=better? - Car Audio Classifieds!
Old 01-14-2012, 04:44 PM
0/11 ssssss639
Default Bigger motor=better?
I have been wanting to build a custom sub for a while now. I just have never gotten around to it. I also don't want something that needs 2k to get stared. What i am wondering, however, is if it is better to just use the biggest motor possible. I want to do a monster 8" or 10". Regardless of coil, is this the right track? I want a monster, efficient sub
Old 01-14-2012, 04:57 PM
surreal's Avatar
0/11 sssss2489
Build something with a strong motor, light moving mass, and put it in a high tuned enclosure then
Old 01-14-2012, 05:03 PM
Rayo187's Avatar
0/11 sssss1127
Feedback Score: 31 reviews
What are your goals for this Sub?..Spl? or SQL?
If you just want something loud for the Meter..Do what "Surreal" suggested..
Old 01-14-2012, 05:16 PM
0/11 ssssss639
Probably SPL. I want to build something that will have people thinking it is a 15 or something.
Old 01-14-2012, 07:23 PM
surreal's Avatar
0/11 sssss2489
Your best bet is a good enclosure and just proper setup within the vehicle.
Old 01-14-2012, 07:26 PM
SoCalBean420's Avatar
время решает все
0/11 sssss7110
Feedback Score: 42 reviews
whatever you decide on having built (sub) have the builder pull actual tsp's. so there is no guessing on the enclosure
“We can ignore reality, but we cannot ignore the consequences of ignoring reality.”
― Ayn Rand
Old 01-14-2012, 07:41 PM
Skip01's Avatar
Ladies MAN
0/11 sssss5551
Nope....bigger is not always better
Youtube VIDz :
Old 01-14-2012, 08:26 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
First: YES, bigger is ALWAYS better. Even if you don't want negative effects like too low of a Q factor from the design. Why? You can do what DC does, HUGE motor, loose gap to coil. It's actually pretty hard to stay on the the low Q side when you are designing and building subs. You can do anything with a large motor, but not much at all with a smaller motor.
Larger motors are best utilized for power handling. Some don't realize that larger motors have MUCH less power compression(coil power handling via the motors say).
If you are wanting a long excursion subwoofer YES.
Remember this: If you want a low FS AND High power handling then you need a large motor for this reason alone because you will need a higher movingmass AND stiffer suspension which both work the opposite at the sub's FS. The heavy cone/coil will try and lower that FS, but the stiff spiders for the power handling are going to raise the Q a bit.
Second: If you want people thinking a smaller subwoofer is a 15" then you need a high XMAX subwoofer, thus, you need a strong motor.
1. Alot of xmax in the gap drives Q up in comparison to a shorter one due to flux density being higher with a closer gap to coil height ratio.
2. If you want it to handle a lot of power you need some stiff spiders which also raises Q.
3. You are also going to want a decently low FS however the long coil will take care of this via weight which is another thing more xmax brings to the table.
So, for a ported low end beast, use a long flat aluminum coil that fits snug in the gap and the spiders would be hard to give a specific figure for, since spider suppliers generally don't give you CMS parameters and stuff. I just go by experience.
Always try and keep the Q low....for low end NO, you dont want too light of an MMS....unless you're using a weak motor. The reason i am assuming you want low end is because you say you wan the sub to sound like a 15".
A woofer tester like the Wt2 is great too....sundownz Uses it.
Old 01-14-2012, 08:34 PM
время решает все
0/11 sssss7110
I would recommend you the TC-9 motor, the most versatile motor to ever be designed or produced
― Ayn Rand
Old 01-14-2012, 08:36 PM
0/11 ssssss639
SO. MUCH. INFO. but thank you so much. I need to do some reading. I wanted to build it myself, but maybe starting with reconing subs would be a better place to start.
Sent from my DROIDX using Tapatalk
WTT Want to go bigger vinniethedon Car Audio Trader (WTT) 1 10-25-2011 05:39 PM
wtb 3k or bigger chris3 Wanting to Buy (WTB) 10 02-21-2011 07:09 PM
FS/FT: RE SE Motor for bigger motor beatnbronco Car Audio Trader (WTT) 0 08-20-2010 11:37 AM
Bigger than 18? dadydolas (Fix My Speaker) 5 02-12-2010 02:44 PM
