Cadence a4 class a old school usa - Car Audio Classifieds!
Old 01-15-2012, 08:52 AM
0/11 sssssss30
Default Cadence a4 class a old school usa
I have a cadence a4 im having trouble with. Im getting engine noise through channels 1 and 2 (front) only. 3 and 4 no noise and no noise through any of my other amps and i have quite a few. I have been troubleshooting in every possible configuration, and have determined its the amp. Is there any suggestions out there as to what it might be?? When the car is not running its crystal clear. I would appreciate any input anyone might have
Old 03-15-2012, 12:07 PM
0/11 ssssss366
Bump any new info I may want it?
Old 03-15-2012, 12:11 PM
qopiyu's Avatar
0/11 ssssss531
are you running separate rca's for channel 1/2 and 3/4, if so, I would be looking at the set of rca's going to channel 1/2. quick test would be to swap the rca's in channel 1/2 to the one's in 3/4 .... do you still have engine noise? if not, it is the rca's going to channel 1/2. Just something to try, good luck!
Cadence 1200rms class D $129 jking29 Hot Deals 10 11-19-2011 06:31 PM
Lanzar Opti Drive 1000.1D made in USA class D mono 1ohm stable gentlejax2 Mono Amplifiers 51 09-22-2011 06:25 AM
Cadence ZRS-C9 Class AB, 4 Channel - LIKE NEW, under warranty meteorshowersca Multi-channel Amplifiers 11 03-26-2011 04:31 PM
Old school U.S. Amps USA-50 c_nitty 2-Channel Amplifiers 5 03-21-2011 11:54 AM
Cadence ZRS2002 2 channel Class A/B Shinju Broken & Non-working equipment 4 06-01-2010 09:16 PM
