2 DDm2s - Car Audio Classifieds!
Old 01-15-2012, 09:07 PM
LivinLoud's Avatar
0/11 ssssss524
Default 2 DDm2s
Im gonna be buying another m2 pretty soon and gonna run them at .66 strapped. Electrical will be 3 yellow tops,2 telecom batteries and a 250amp alternator. About how much power will I get from the amps. Reason I wanted to know is beacuse I email DAD about some 12s and they wanted to know how much power it will be. I gave it a ball park guess at 2800. But wasn't sure.
Team Tantric Sounds
2 Tantric Sounds HD 15's
2 Digital Designs M2a's @.5
155.5 outlaw
REF:Loudwhat?,Retroaudioinc, statonburrell,Ho-Audio
well hello fartbox zen master
lol
Old 01-15-2012, 10:08 PM
schmiddr2's Avatar
ΞΞΞΞΞΞΞΞΞΞΞΞΞΞΞ
0/11 ssssss428
Sounds about right to me. It will spike higher of course.
14.4V x 250A = 3,600W. 3,600W x 80% efficiency = 2,880W.
Email DD and ask them. I'm sure they will be able to get you real close.
Old 01-15-2012, 10:12 PM
mega fatty
0/11 sssss6008
.66 strapped you could probably see a solid 4k out of the pair
its 1700 @ 1ohm on 12v, so you can expect around 2k at 14.4 and being strapped at .66 hopfully your rise will be below 2ohm and you should get a decent amount of power.
.66 strapped is low for any amps daily though so be careful
07 mazdaspeed3
rd d9 @ .5ohm
The Following User Says Thank You to tymoto21 For This Useful Post:
taylorpro (01-15-2012)
Old 01-15-2012, 10:17 PM
LivinLoud's Avatar
0/11 ssssss524
Got a buddy of mine running his at .66 that will be helping me get everything straight. He been running his like that for some time now. I probably won't run that low daily only run that comp.
Team Tantric Sounds
155.5 outlaw
lol
Old 01-15-2012, 10:44 PM
schmiddr2's Avatar
ΞΞΞΞΞΞΞΞΞΞΞΞΞΞΞ
0/11 ssssss428
tymoto, you are calculating the amplifiers potential output, correct? If so do you mean 4KW clamped or peak? I don't know much about clamping or real world peak numbers, so if you care to explain how this works I'll listen. When I see 250A I calculate from there.
