0 gauge quick dissconnect? - Car Audio Classifieds!
Old 01-17-2012, 09:07 AM
infaredsinsor's Avatar
0/11 ssssss769
Question 0 gauge quick dissconnect?
Has anyone every ran across an automotive application for a 0 gauge power wire quick disconnect? I was just wondering because it is just a pain to keep messing with set screws on an amplifier or a battery when you need to do work or change out a "setup". It seems like a quick disconnect would just make life a little easier....
"Smarter, not harder"
Subs, amps, and power
AFEX Fire Suppression Systems Quality Engineer
itrader info available on profile
Old 01-17-2012, 09:09 AM
younggunzbass01's Avatar
0/11 sssss1653
Isnt that what those two allen bolts on a fuseholder do? Thats essentially what your doing by removing a fuse.
Old 01-17-2012, 09:10 AM
Second Skin Rep Jon's Avatar
Vibration Consultant
0/11 ssssss412
Like this?
LINK
If so, yes they are AWESOME.
Have a question about
? Shoot me an
The Following User Says Thank You to Second Skin Rep Jon For This Useful Post:
infaredsinsor (01-17-2012)
Old 01-17-2012, 09:17 AM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
in an environment that is plagued with vibration, i would not rely on quick disconnects ever.
my 4 year old can use an allen head/ratchet, its not that hard
TeamGG
Team D.O.A.
Old 01-17-2012, 09:22 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Have you pulled one of those things apart recently? I damn near have to bust a ball just trying to get them apart sometimes!
I don't see any problem with them coming loose. Its more the current draw I would look at. If your pulling a ton of current I would look for another solution personally.
UL amperage*/voltage rating: 175 amps/600 VDC
Operating temperature range: -20 to 105 C
Current rating*: 175 amps on 1/0 AWG wire produces 30 C rise
Insulation with standing test voltage (volts, dc): 2200dc
Maximum wire insulation diameter: 0.75"/19 mm
Average contact retention force: Approximately 300 lbs.
Average contact resistance: With 1-3/4" (45 mm) of 1/0 AWG wire 100 Ω
Vibration resistance: Excellent
Mating cycles: 10,000 / For disconnect use only
Impact resistance: High
Environmental restrictions: Protected-no hydrocarbon fluids
Flammability Rating: UL94V-0
Average mating and unmating force: 25 lbs (11.25 kg)
Old 01-17-2012, 09:49 AM
0/11 ssssss769
I know that turning allen's aren't difficult. I am not really asking for a solution to any problems either. It just seemed like a good idea for some applications. I do like the ones proposed from Second Skin Rep Jon. I don't have a monsterous electrical system to support, so these could possibly be ideal for someone like me. Thanks for all the input though.
Old 01-17-2012, 09:53 AM
Ja Marcus
0/11 sssss6975
Look at Parts express if you do get them. They are about 1/2 the cost of the ones in the link provided.
Old 01-17-2012, 10:06 AM
bigdhenderson's Avatar
0/11 sssss4981
Feedback Score: 45 reviews
why not welding quick disconnects? then just run a little electrical tape around the joint to make sure they wont come apart
The Following User Says Thank You to bigdhenderson For This Useful Post:
iamsonic (01-17-2012)
Old 01-17-2012, 10:08 AM
Ja Marcus
0/11 sssss6975
Those can be kinda of pricey. But another good option.
Old 01-17-2012, 10:20 AM
Dunder Mifflin
0/11 sssss1897
Summitracing.com has them there used in racing applications !
jordan i want my subs
quick ? bout battery wiring...need quick answer [email protected] General Car Audio Discussion & Questions 9 09-02-2011 01:32 PM
[SOLD] Random wires(4 gauge, 8 gauge, 12 gauge) Pieper Wiring, Electrical & Other Installation Equipment 4 03-06-2011 12:10 PM
quick question need quick answer 05xxx perfect_prefect General Car Audio Discussion & Questions 0 01-25-2011 02:44 PM
Looking for a 0 Gauge Dist block with one 0 gauge output & one 4 gauge out AuZy_AuDiO (Shok Ind) 5 10-14-2009 11:09 PM
Quick question... Answer QUICK please its getting dark soon Sonically_Sound General Car Audio Discussion & Questions 11 10-03-2009 07:41 PM
