center console build help anyone?? - Car Audio Classifieds!
Old 01-17-2012, 06:46 PM
0/11 ssssss134
Default center console build help anyone??
i am building a center console SPEAKER not subwoofer box for my 2001 silverado!
i have a 15 inch robot underground/ soundsteam splx/ audiopulse subwoofer!
2 tang band 5.25 full range soeakers and 2 polk db tweets in each door
doors are on an old memphis 4 channel and the robot sub will be on a massive audio nano n4
i want some help with the center console and here are my thoughts on it allready...
-2 cdt m6+ 6.5 inch midbass speakers these are 4 ohm each
or
-2(of any high end) 8 inch mid bass/range speakers 8 ohm
or
-1 (any high end) 10 inch mid bass/range speaker 4 ohm
the speakers will be more towards the dash and further back i will have a little box to hold my phone and 2 cup holders!
thanks ahead of time for the help guys!
Old 01-17-2012, 10:53 PM
schmiddr2's Avatar
ΞΞΞΞΞΞΞΞΞΞΞΞΞΞΞ
0/11 ssssss428
2 - 8"
Like these - Peerless 830667 8" Paper Cone SLS Subwoofer 264-1102
EDIT: What amp for midbass, and what crossover points/slopes? Will they be sealed enclosures?
I like the equipment you have so far. gj.
The Following User Says Thank You to schmiddr2 For This Useful Post:
buttphacekilla (01-19-2012)
Old 01-18-2012, 02:12 AM
gibsonm21's Avatar
0/11 ssssss392
JL zr800s are actually some of the best sounding mid bass drivers on the market. I'm doing the same thing in my tahoe w/ a 2 cube box tuned to 32hz with a 2 inch aero. I plan on crossing them 60-250 @ 6db slope since I often listen to my system with the subs off.
"WHEN you're thinking of replacing a blown fuse with a higher rated fuse ask yourself if you know more than the engineer who designed the equipment."
Old 01-18-2012, 05:43 AM
0/11 ssssss134
i have a jl 300/2v2 for the amp and im very picky on how the speaker looks(idk why)
i would like a very clean looking speaker the peerless aren cutting it for me
also i will have them at 50 hz and up and im looking more for a mid range spaker that will
put out some nice midbass
Old 01-18-2012, 05:49 AM
0/11 ssssss134
also what type of crossover should i run if im going to do a mid range from about 50 - 4k?
Old 01-18-2012, 05:54 AM
0/11 ssssss215
If the speakers in your console are firing up you will hear them more easily you may not need large drivers for this as they will be louder because of placement. Id use 6.5s
Old 01-18-2012, 05:56 AM
0/11 ssssss134
i was thinking that to i can have the 6.5 at more of an angle because of the size!
Old 01-18-2012, 07:12 AM
schmiddr2's Avatar
ΞΞΞΞΞΞΞΞΞΞΞΞΞΞΞ
0/11 ssssss428
The TB fullrange can easily play from 300Hz up to 4KHz, and do it with less distortion than most 8". That's just my advice.
But for recommendations in your setup, B&C 6NDL44 6-1/2" Neodymium Woofer 294-647
Old 01-18-2012, 07:49 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
What?!?! Your tuning to 32hz and then crossing them over at 60hz? That doesn't make since as your almost a full octave lower on tuning then crossover point.
Unless I miss-read what you wrote.
Old 01-18-2012, 10:53 AM
0/11 ssssss134
The while reason I was looking at the cdt m6+ was because the get down to 50 Hz easy which will be my crossing point. I am looking for a mid bass/range speaker not just one or the other but thanks for helping!
any I the suggestions?
Need help on a center console RetroAudioInc General Car Audio Discussion & Questions 15 02-07-2013 06:13 PM
Center Console Box??? chance174 Enclosure Discussion & Design Construction Help 4 12-31-2010 12:56 AM
center console sub box? 98Expo General Car Audio Discussion & Questions 4 08-12-2010 01:20 PM
2006 CRV center console build! andrewtexas123 Build Logs 25 06-25-2010 08:22 PM
Mounting a sub in my center console tahoebrotha General Car Audio Discussion & Questions 10 12-29-2009 04:52 PM
