Big 3 question - Car Audio Classifieds!
Old 01-17-2012, 07:02 PM
0/11 ssssss150
Default Big 3 question
Hey everyone,
So, I finally got around to installing a new system in my mustang (2000 v6) and decided to do the big three due to lights dimming. Here's some background info first.
I'm currently running an MB Quart DSC1500.1d on a single SkarVVX-12 D2
Stock alt (130 amp i believe) and Deka battery.
Before I did the upgrade my battery with car off would rest at 12.2v 14.1 idle.
After I did the upgrade (with 0ga wire) my voltage rose to 12.33 with car off and 14.53 idle, however.... lights dim even more now.
My power and ground wire are 4ga wire with a 100 amp fuse near my battery.
Am I missing something? Ill post pics of my big 3 a little later when I get my new phone (probably tonight or tomorrow).
I did alt+ to batt+
batt- to alt casing
and bat- to chassis
Is my big 3 shorting? Or is it working and I just need to upgrade my battery? Any suggestions would be appreciated!
Thanks!
Old 01-17-2012, 10:24 PM
0/11 sssss1691
my understanding is that its just taking more juice and ur lights will ALWAS dim lol reguardless unless u have about 6 batterys loland a nice alt then it may not dim at all or so little u wouldent even notice.
1996 Chevrolet Impala SS
sub stage : 2 12 orion hcca d2
mids and highs stage: nothing yet
Amps:
bass amp: nothing yet
Mids and highs amp :Audison sr5 for now more to come
Old 01-17-2012, 10:29 PM
Bologna's Avatar
Ad ministrator
0/11 sssss2872
Take a run from your negative battery to your engine block.
Also I always use 1/0 gauge. Depending on your car, it could have had 4gauge on it for stock
Refs: BlackWaterOp x2, Master69 x3, Scottie x3, RidnClean, JusBlaze (Scammed Me), SPLaudio x3, ltr450racer690, dbeez, LuisT, SPY, Mgcauctions09 x3, pieper88 x3, scottyk, Jh8909, JB312, stretch, Mechman, 01SpyderDB23, andrewtexas123, 50 black guys, bubbagumper6, btr, SacTownBully84
Old 01-17-2012, 10:40 PM
mtrevino92's Avatar
0/11 sssss1526
Feedback Score: 21 reviews
Originally Posted by Griff1220 View Post
Hey everyone,
I did alt+ to batt+
batt- to alt casing
and bat- to chassis
Thanks!
You say you upgraded to 0ga, but you have 4ga near your battery. You should go with all 0ga and see it that helps.
The Following User Says Thank You to mtrevino92 For This Useful Post:
fasfocus00 (01-17-2012)
Old 01-18-2012, 01:09 AM
0/11 ssssss150
Okay let me clarify, all big three wires are 1/0ga wire.
Alt+ to Bat+
Bat- to Chassis
Bat- to block
All of which are 1/0ga
My power and ground wire for my amp is 4ga wire, grounded in the trunk to the body
Old 01-18-2012, 05:03 PM
BFF Larry's Avatar
0/11 ssssss118
Do a run chassis to engine block or alt casing to strut.
Some cars with no matter how many batts, will always have dimming.
Old 01-18-2012, 11:44 PM
0/11 ssssss150
Okay, so i finally got around to taking pictures of my big 3. Sorry, it was late when i took them.
Again, sorry for the quality.
Old 01-19-2012, 03:16 PM
0/11 ssssss150
Anyone?
But those Tantric MDs have a 2.5in VC and they are also on a different level for a "750wrms" subwoofer.. All their products are retarded.
Old 01-19-2012, 08:15 PM
BFF Larry's Avatar
0/11 ssssss118
replace 4 gauge with 1/0 if possible, and check if any wire is getting hot at all, loose terminal rings can cause an array of problems
3 flips. nollie flips. big flips. hardflips. - steez
New Build- in Progress
- WALLED 95 Bonneville -
(1) Iraggi 320 amp *rebuilt by MechMan*
(2) DC Level 5 18's
(1) Cactus Sounds K12
(1) SounDigital 8000.1 GONE
(2) AP 3000.1d GONE
*thanks Logan**thanks CortezDVT**thanks Cj and SuperCharged DC**Thanks Ryan,RAM Designs*
Old 02-16-2012, 02:46 AM
0/11 ssssss150
I actually checked all my connections and they were fine. Also wired a new battery in parallel in the trunk and lights still dim quite a bit. Dont know what my problem is. I have battery in back grounded to front battery and chassis and the amp itself is grounded to back battery. Can't figure out why my lights are dimming so much.
The big question! deanmachine General Car Audio Discussion & Questions 11 04-02-2011 12:39 AM
Big 3 Question?? wcjake15 General Car Audio Discussion & Questions 6 12-29-2010 11:02 AM
Big Big question, need help... masterbarber General Car Audio Discussion & Questions 31 10-13-2010 09:12 PM
Big 3 Question Ronin General Car Audio Discussion & Questions 14 10-05-2009 11:42 PM
big 3 question tater General Car Audio Discussion & Questions 38 12-08-2008 08:51 AM
