Turning SA-8s into 2 SA-8 based 15s {quick questions} - Car Audio Classifieds!
Old 01-17-2012, 11:28 PM
jwright0291's Avatar
Big Ballin
0/11 sssss1468
Feedback Score: 23 reviews
Default Turning SA-8s into 2 SA-8 based 15s {quick questions}
I have 2 sa-8's coming and I wanna make 15's. How do I remove the basket?
And would it be worth it to get psi recones or do sundown recones hold up good?
Old 01-18-2012, 05:00 PM
BFF Larry's Avatar
0/11 ssssss118
Get the sundown recones for the sa 15s
Old 01-18-2012, 05:09 PM
0/11 ssss31258
2 SA-8s turned into 2 SA-8 based 15s;
get 2 15" baskets and drill the 4 bolt pattern in them.
then buy 15" cones with 2" coil openings and the best surrounds you can get for maximum throw.
then buy the coils for SA8s
then buy spiders which have the 2" ID and the appropriate OD.
Then build them.
PS;
removing the basket is simple.. just remove the four screws.
LoudSpeaker Cone- 15" Paper/ Rubber Surround Orion, ADS | eBay
pile used frames most sizes part II - Car Audio Classifieds
Old 01-18-2012, 05:44 PM
stylez12321's Avatar
0/11 sssss2192
Feedback Score: 37 reviews
Psi doesnt do 2" coils
Old 01-18-2012, 07:18 PM
Active Member
0/11 ssssss731
Be easier to just buy two sa15's
97 cherokee
Sub: 4 Sundown SA-8's Sub Amp:Orion XTR PRO 2400
Highs amp: Orion XTR 800.4 mid and Tweet: Tantric Sounds Component set
The Following User Says Thank You to etznova For This Useful Post:
goatskindreams (01-18-2012)
Old 01-18-2012, 07:19 PM
Team Retribution-DJ's Avatar
0/11 sssss1934
The motor is different ,and you would have drill new holes in the basket
It would make more sense to just get SA 15s
TEAM XS POWER -TEAM MECHMAN
quick ? bout battery wiring...need quick answer [email protected] General Car Audio Discussion & Questions 9 09-02-2011 01:32 PM
quick help RidnClean General Car Audio Discussion & Questions 3 08-10-2011 11:53 AM
quick question need quick answer 05xxx perfect_prefect General Car Audio Discussion & Questions 0 01-25-2011 02:44 PM
quick 2 questions nuboot (Fix My Speaker) 0 01-23-2011 06:53 AM
Quick question... Answer QUICK please its getting dark soon Sonically_Sound General Car Audio Discussion & Questions 11 10-03-2009 07:41 PM
