how much port area per cube for a 4th order - Car Audio Classifieds!
Old 01-18-2012, 11:16 PM
0/11 sssssss93
Default how much port area per cube for a 4th order
im looking to try a 4th order with my oa 15 but im not sure on the size of the port, do you just size it like a regular ported box or do you go larger??
Old 01-19-2012, 04:06 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
There's no hard and fast rule. Although, I like ~ 25sq in per cube give or take depending on the application.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 01-19-2012, 09:31 AM
Audio_phill's Avatar
Too Busy to be here
0/11 sssss2297
Feedback Score: 23 reviews
port area should be devised using vas and qes, not enclosure volume lol
Bought From: Funky Waves, Realbeach, Farmacist Louisiana_CRX, Lingerfelt, ciaonzo, SPY (X2), tristanmay, bigbassjoel, Sound_Around, Good Times
Sold To: alfabit1, Sound_Around, jonalford2087, woodels420, pangullo, chico305, ciaonzo, darkkon, faessle, UNDERGROUND_BUM, JCJR, adrian1185, fast306stang, tristanmay, biggen_bd, mwerling1212, HiloDB1, statonburrell
Traded With: HiloDB1, kn0wledge000, ciaonzo, tristanmay, Jh8909, fritosaregood
Old 01-19-2012, 09:35 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
What is this vas and qes you speak of? This is why people are so scared to try bandpasses. All of this hokey pokey mumbo jumbo that seemingly only 4 people in the world know how to interpret and use. It ain't flippin rocket science. It's a damn speaker box.
That ain't how I roll. I jab it in a box inside of a box and make a big fat port and let 'er eat.
4x world champ
- Floyd E. Toole
Beatnoutdaframe (01-19-2012)
Old 01-19-2012, 09:45 AM
0/11 ssssss761
Make it big see what it does and start shrinking it until you find where's loudest
J.D. Merkle
TEAM SOUTH
4 DD 9512H
2 DD M4a
Old 01-19-2012, 09:46 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Just one more little note about it since you gave me a little giggle there at the end...
Last year I wanted a 4th for a 12. I got a "guru" to design me one, I used WinISD for one and then I straight up guessed at one. I built all three. Guess which one was loudest and had the best FR?
4x world champ
- Floyd E. Toole
Old 01-19-2012, 01:23 PM
0/11 ssssss296
what makes a sub a "good choice" for a 4th order box? Are obsidians considered a good choice? the 18 ?
Obsidian 18" D2
Re: 4.0 Ohm
Fs: 26 Hz
Qms: 4.4
Qes: 0.76
Qts: 0.65
Vas: 170.1
Le: 2.21 mH
BL: 18.5
SPL: 88 dB
Sd: 1217.3 cm^2
Mms: 437 g
Xmax: 20mm
Peak-to-peak: 62mm (2.45")
Power Handling: 600 watts RMS
Recommended enclosure info:
Sealed ~ 3.5 to 5 ft^3
Ported ~ 5 to 7 ft^3 @ 28 to 32 Hz
Cutout: 16.7"
OD: 18.375
Mounting depth: 9.5"
Mounting flange to top of surround: 1.5"
Displacement: 0.25 ft^3
Old 01-19-2012, 01:24 PM
HACKMUNCH's Avatar
0/11 sssss3892
yes, high qts, high vas. 2.5" coil = low power
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
Old 01-19-2012, 01:41 PM
0/11 ssssss267
what do you consider high qts and high vas
Old 01-19-2012, 02:06 PM
Re_Silverado's Avatar
0/11 ssssss590
Non wall= less port if not a lot of power
Wall setup= more port depending on how much power as well.
Could range anywhere from 12-25 sq in per cube depending on the application. For low end extension, more port is better in most cases.
4th order port through rear deck need design help, and build help in MN or IA area maddog2099 Enclosure Discussion & Design Construction Help 6 05-21-2011 09:19 PM
quick 4th order help. port sizing. Violence* Enclosure Discussion & Design Construction Help 12 01-05-2011 05:21 PM
Port through rear deck, 4th order? Jh8909 Enclosure Discussion & Design Construction Help 11 02-06-2010 12:10 AM
4th order/slot port help king ranch Enclosure Discussion & Design Construction Help 26 08-03-2009 09:53 PM
