to the cavalier or other unibody owners.... - Car Audio Classifieds!
Old 01-19-2012, 04:15 AM
0/11 ssssss227
Question to the cavalier or other unibody owners....
i drive a 2000 Chevy Cavalier (4 door if it matters too much) and i was wondering where a good place to run extra wire would be? 1/0 welding cable/wire. i have one run under the trim panel for the doors (front and back doors) and under my back seat etc etc. i was wondering if i could get abnother run under there? or if its a good idea, i wanna hook up a second battery, but idk yet seeing as how i only have the positive wire going back to my amp....oh, and some good, safe grounds without mutilating my daily driver :P and i also dnt have a lot of time to do it all at once, so if it can be split up or something, thats be amazing! Any input/advice is apreaciated.
Thanks,
Alex
Old 01-19-2012, 05:30 AM
Post whore with a cause
0/11 sssss1937
Feedback Score: 22 reviews
I don't own my Cavy anymore but I'd just run it under the car. There's not to much free space for concealment on the inside lol
Well I got something for you from the late great Colonel Sanders who said "I'm too drunk to taste this chicken"
Old 01-19-2012, 05:40 AM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
U can use the rear seat belt anchor bolts as grounds just make sure u grind away all paint, top anchor points should be accessable threw trunk and lower ones r under rear seat
Sent from my ADR6400L using Tapatalk
2005 Buick LaCrosse
HU: Alpine INE-S920HD
Old 01-19-2012, 12:30 PM
0/11 sssssss91
under the car is the fastest ...
Old 01-19-2012, 12:33 PM
0/11 ssssss227
Should I put electrical tape around the lugs then so it dnt arc to the rest of my car and possibly light my back seat on fire? Lol and I guess ill hafta find a way to run it under my car (the wires) but the hard part is just getting under it lol no ramps or lifts here :P
Old 01-19-2012, 12:53 PM
schrummy's Avatar
0/11 ssssss288
got a 98.... i ran mine through the boot under the master brake cylinder, then down the center of the car, (ran it on the side of my center counsel) ran it straight back to the back seat where it shifts over to the side panels and goes into the trunk...had 6 runs with no signs of it. also was able to save about 2 ft per run
150 db @ 33hz
Team Midwest
Old 01-19-2012, 01:32 PM
0/11 ssssss227
Got a pic of it? Lol cuz I want it hidden so nobody sees it, but once it gets behind the seat it dnt much matter if it can be seen (for now)
Old 01-19-2012, 01:50 PM
SPLpizzaguy's Avatar
Humbled by CACO
0/11 sssss3111
Feedback Score: 57 reviews
Under fusebox is a gromet to get to inside under dash pull wire through. Remove front seat as well as trim panel. Remove back seat as well as trim panel. Run from under dash,under carpet, inbetween seat bolts, under back carpet, under backseat. It all in taking the seat out. I put 2 cadence amps in a 2000 for my brother. Don't know if it is the same for a 2004 or not.
I could never run it under the car. To afraid of rust, as well as wire wear. These amish roads out here are gravel.
4 sa10s
Taramps 8k
4 American Bass VFL 6.5s
Ohio Generator 305 amp alt
4 Vifa Tweets.
Old 01-19-2012, 01:51 PM
Humbled by CACO
0/11 sssss3111
Niiiice.
4 sa10s
Taramps 8k
4 Vifa Tweets.
best way to ground battery on trunk with unibody ? michigancapri92 General Car Audio Discussion & Questions 9 02-12-2011 09:08 PM
04 cavalier quote brian_smith06 General Car Audio Discussion & Questions 1 11-21-2010 10:13 AM
cavalier h.o alt LoudCavi Wanting to Buy (WTB) 13 08-24-2010 02:52 PM
? for aq2200 owners or ex owners notloudenuff General Car Audio Discussion & Questions 31 05-28-2010 05:07 PM
Maxima Owners and Trunk Owners Please Look Inside! strpperpolef150 General Car Audio Discussion & Questions 13 06-06-2009 09:13 PM
