will my electrical be good? - Car Audio Classifieds!
Old 01-19-2012, 01:35 PM
0/11 sssss8594
Feedback Score: 55 reviews
Default will my electrical be good?
Mike Singer said he can make an alt for my car so that just changed things
im gonna have a 200a alt...im gonna be using about 6k worth of power...i did this before in my mustang (opti6k) and i had 1 s3400 and 2 d3400 and i was dropping to low 12s (but i think that was the shitty 220a powerbastards alts fault)...would that same electrical with an alt that ACTUALLY does 200a be fine for 6k?...i think i should be good but figured id ask the pro...i wanna do 2 d3100 but the weight would just kill my 4cylinder...lol
so basically,
200a alt
1 s3400
2 d3400 or xp2000
2 runs 1/0
6k
stay above 13v??
Enclosures
Old 01-19-2012, 04:27 PM
0/11 sssss1016
You will not stay above 13V with that no way. 12V batteries highest resting voltage with a load will be 12.9. If you are running 6k, then you are pulling approx 600amps of power for the system. 200amps of alt power (at peak output) has you over 400 amps behind on power (have to also count the amperage to run the vehicle). That would have you pulling 400amps + out of the batteries.
You would probably fall into the low to mid 12v range. If you can add an XP3000, XP2500, or XP2000 in the back you would probably be ok on power.
'1.888.497.7693 x1211
Old 01-19-2012, 04:35 PM
SPL Distribution Owner
0/11 sssss2983
yep, and all alts are rated cold unless otherwise stated.
That 200A alt will more than likely do 160-170A max once the engine bay warms up.. which only takes a couple minutes.
Old 01-19-2012, 04:41 PM
tacomaguy1's Avatar
0/11 sssss4401
^ I hate watching my voltage go down when my truck warms up...without even playing anything either lol
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 02-04-2012, 07:25 PM
0/11 ssssss201
make it 3 d3400 and i think you could be around 13v because are you really going to be pulling 6k all the time? nah so at times high 12s(12.7-12.9) but most of the time low 13s 13-13.2
Team Skar Audio
[SIZE=2]
'03 explorer 4.6l v8 (Legal [email protected] with 2 15" VVX on a BC2000 @.5)
New setup is underway!
Old 02-04-2012, 11:29 PM
0/11 sssss8594
ya, ive upped my batts...im gonna be grabbin 2 xp3000 instead and a s3400
Enclosures
Old 02-24-2012, 11:13 AM
0/11 sssss8594
just thought about this...will a 200a alt, s3400 and 2 xp2500 hold up on that opti6k??...if i dont need to spend the extra money/weight for the xp3000, i dont wanna...if i have to, i def will tho
Enclosures
Old 02-24-2012, 11:22 AM
Matt3824's Avatar
0/11 sssss3754
I'd do 3 D3400s. But that's just me.
Old 02-24-2012, 11:23 AM
0/11 sssss8594
im gettin in on the group buy so XP's are gonna be in the rear
Enclosures
Old 02-24-2012, 11:31 AM
99Bonney's Avatar
0/11 sssss6246
I'd say yea. Xp's together are good for 5k plus your 3400. Do it up.
2006 Tahoe
Subs- 4 Crossfire xs v2 15s
Amps-Crossfire 8k
Batts- 6 xs 3100s, 2400
Alts- 3 Mechman SMD 340s
advanced electrical question on a/c electrical wire fatigue slowpoke General Car Audio Discussion & Questions 18 12-04-2011 01:40 AM
o5 dodge magnum-whats a good electrical system? 83eldorado General Car Audio Discussion & Questions 12 10-29-2011 12:50 AM
How good of electrical? mythyone (Crescendo) 10 05-10-2010 08:04 PM
Electrical Good Enough? PHATBOi General Car Audio Discussion & Questions 9 11-29-2009 08:04 PM
My electrical good enough? snow90 General Car Audio Discussion & Questions 4 08-07-2009 05:09 PM
