No power look inside - Car Audio Classifieds!
Old 01-19-2012, 09:07 PM
18psi's Avatar
0/11 ssssss500
Default No power look inside
I have a hifonics Brutus 2610 that doesn't work.
Blue led at top lights up but it doesn't power on.
Months ago while installing this we hooked the power an ground backwards( I know insert flame here)
Anyways, I just got around to opening the amp and found this
Would this be the cause of the problem? Notice the piece on the left is cracked...
There is no other parts showing burns or anything abnormal...
There is a place local that can fix..
My question is , can I do this, ?
Old 01-19-2012, 10:00 PM
Pioneer621's Avatar
0/11 ssssss495
Those look like the reverse polarity diodes, they blow when the amp is hooked up backwards There supposed to blow the amps fuses before any or major damage is done, but thatís not always the case.
If the amp was fused properly, check the fuses obviously as they may have saved it (those diodes still need replaced or checked for shorts though). If not your power supply transistors may be blown & or possibly a burnt trace between the diodes & the power terminals. Maybe other problems as well, hard to say.
You can check those with an ohm meter to see if there shorted. If they are the reverse polarity diodes (connected to the GND / B+ terminals of the amp) the amp donít need them to work & would work fine without them, but they should be replaced for a proper repair & any future backwards connections! The power supply transistors should be checked as well etc.
Thatís about all the input I can add. If you are not sure how to check any of that I would suggest having a good repair shop fix it for you. Iím sure some others can try to help if you want to try to repair it yourself though.
Old 01-19-2012, 10:01 PM
0/11 sssss2429
Feedback Score: 46 reviews
That is a reverse protection diode. Cut it out and see if it will work, it may have deeper problems.
Sent from my Punch 60.2
Old 01-19-2012, 10:31 PM
18psi's Avatar
0/11 ssssss500
Yea, last time I ever had a beer while installing... 1st amp I ever f'd up
Best L.E.D.s for inside a box? oxsign General Car Audio Discussion & Questions 8 09-18-2010 08:54 PM
WTT Looking for a pair of high power handling 10" subs, inside for more detail! Shinju Car Audio Trader (WTT) 32 05-03-2010 05:55 PM
12v power source, from inside of amp? FatBoy2 General Car Audio Discussion & Questions 17 01-17-2010 10:34 PM
sexy look inside GODHATESCIVICS General Car Audio Discussion & Questions 8 11-22-2009 02:31 PM
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
