Is this guy correct? Amp question - Car Audio Classifieds!
Old 01-19-2012, 09:01 PM
Nik592's Avatar
0/11 sssss2000
Default Is this guy correct? Amp question
Posted up the pics of my little audio build in the SRT and he put this post up about the Audiopipe 18001D
"looks nice.
i hate to be the bearer of bad news but the manual for that amp calls for a minimum of 2g with 0g preferred. that 4g is too small for the sub amp, especially if you plan on running it at 1ohm, and way to small if you plan on adding another amp in the future.
i really hope that you told the box builder what sub you were going to use and that it was built to the proper specs (not necessarily what the manual says but what it needs). sticking any sub in any ported box can have some terrible results.
not trying to be mean or put your stuff down, i just want to help you avoid any problems."
is this correct?
Here is my response
"Thanks for the info man but... I'm not quite sure how I'm suppose to fit 0 or even 2 ga in 4ga toolmaker inputs?
these inputs are JUST big enough to fit the 4 gauge I have..
I think you might of been looking at a different AP amp?
There's quite a few models with some of them that do have 0 gauge inputs but certainly not this one
And yes the box was made specifically FOR the T2 to spec and everything
the audio shop I had build it is also the installers for the ABC warehouse in Bay City, Mi
I ran my Rockford T2000BD on some thick RF 4 ga and that thing sucked power like a black hole
I think I'll be alright =)
I been in the game a while so I know a thing or two
Lol"
"Insert witty signature here"
Old 01-19-2012, 09:05 PM
oslouie's Avatar
0/11 sssss5073
Feedback Score: 69 reviews
If you're asking if 4 gauge wire will work for you, yes. Is it sufficient for 1800 watts? I'd try to go bigger if i could. I wouldn't feel comfortable using 4 gauge for anything more than 1200 RMS.
Sent from my EVO 3D using Tapatalk
Old 01-19-2012, 09:06 PM
Nik592's Avatar
0/11 sssss2000
I'm just wondering because there is no dang way 0 gauge will fit in these terminals
Their tiny
Old 01-19-2012, 09:10 PM
18inchjeepin's Avatar
0/11 sssss1931
Feedback Score: 37 reviews
maybe install bay or raptor 0 awg
Silver HHR
TEAM SOUNDSTREAM
XS Power D3100 with Toolmaker blocks
Alpine 9884-> Soundstream RUB4.600-> Soundstream SST-05 tweets-> Soundstream 804N 8" neo mids
A-pipe mini 1500-> pair Sundown SA15's -> 4th order wall
mylows10's Avatar
0/11 sssss2210
Feedback Score: 17 reviews
then run 2 runs of 4 gauge and get dual inputs.or a 0 to 4 gauge adapter
Nik592's Avatar
0/11 sssss2000
is it pretty thin for 0?
I had a time just putting this 4 in the terminals
Old 01-19-2012, 09:17 PM
727Designs's Avatar
0/11 ssssss245
Last AP18001 I installed for someone I ran 0 all the way to about 6" from the amp, then used a distribution block to a 6" piece of 4awg to finish it. Worked fine.
The Following User Says Thank You to 727Designs For This Useful Post:
profundus-sanus (01-19-2012)
Old 01-19-2012, 09:23 PM
Nik592's Avatar
0/11 sssss2000
Good idea I'll probably re run to a dist block
Old 01-19-2012, 09:29 PM
BlackWaterOp's Avatar
Super Moderators
0/11 sssss4420
Feedback Score: 35 reviews
That's some rigged shit right there.
eBay (douglas.leejr) 666+ Feedback 100% Positive
PayPal Premier Verified Since 2004 (
E-thug:
If u dont wanna be here i can make sure u get the banhamma
lets keep it as simple as that.
Old 01-19-2012, 09:30 PM
Nik592's Avatar
0/11 sssss2000
LOL
What would you suggest black?
Is this design correct? k3n12ock Enclosure Discussion & Design Construction Help 3 01-15-2012 10:29 AM
does this look correct? knockinthastreetzof608 General Car Audio Discussion & Questions 12 04-10-2011 01:19 PM
Just making sure this is correct? jrplayer36 General Car Audio Discussion & Questions 0 12-15-2010 10:00 PM
Is this Correct? beany General Car Audio Discussion & Questions 26 11-01-2010 08:33 PM
Need an amp, need your help to find a correct one. Bologna General Car Audio Discussion & Questions 3 04-27-2009 08:52 PM
