problem with my new dc alt :[ - Car Audio Classifieds!
Old 01-20-2012, 01:21 AM
0/11 sssssss34
Default problem with my new dc alt :[
so i finally got my 180 hp in for my 97 honda civic and idk if somethings wrong with it or not but im dropping to 11.8 still and sometimes when i start my car my car runs like shit and sits at 13.5 and a few seconds later will charge back up and my max voltage is 14.3 it should be higher i believe the alt gets hot as hellllllll too idk what it is :[
Old 01-20-2012, 02:02 AM
0/11 sssss1250
Feedback Score: 34 reviews
belt tight enough?
and when you say runs like shit, what do you mean?
Best thing to do is to call DC Power and tell them your situation. Best way to get the right solution.
SPL-Lab REP
Want an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has more features and more support? PM me.
Old 01-20-2012, 02:13 AM
slowpoke's Avatar
newbie forever
0/11 sssss1160
remove the belt and start your engine, if it runs fine then i would say the alt is binding. if its the same then you have other issues.
Old 01-20-2012, 03:10 AM
0/11 ssssss201
Your ELD limits you. No H/O alt will work any better than the stock unless you bypass it.
Old 01-20-2012, 03:20 AM
0/11 sssss3986
exactly what he said. kick on your fan for your heater or ac and i bet it turns the alt on. thats what i have to do with my civic hatch d15
Old 01-20-2012, 06:59 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
1) did you put a 1/2" shorter belt on?
2) did you charge your batteries prior to installing the alt?
Old 01-20-2012, 10:47 AM
0/11 sssssss34
U kno what I use to have to use my af on my stock alt for it to work and no I didn't use a 1/2 smaller belt and my batteries were sitting at 12.6 before installation thanks for the help every one ill have to just go down to dc
Old 01-20-2012, 10:48 AM
0/11 sssssss34
Lol and seriously i cannot describe how its runs like shit ud have to see it
Old 01-20-2012, 10:56 AM
0/11 ssssss410
Just a little info on Honda's all the engine grounds must be connected I think theirs like 8 of them I'd start their with the bad running issues
~ PJ ~
Old 01-20-2012, 02:21 PM
0/11 sssssss34
thanks man ill check it out
Stock 140a Alt for GM 3800 Series II or a cheap HO alt Raptor660 Wanting to Buy (WTB) 10 04-08-2011 07:11 PM
Problem with my MM Alt MikeyF General Car Audio Discussion & Questions 23 03-15-2011 01:53 AM
Unique dual alt PROBLEM, made a vid to watch!! NorthBeat General Car Audio Discussion & Questions 18 08-10-2010 09:01 PM
problem with 3kwp [Problem Solved] jizazz12 (Crescendo) 10 04-30-2010 06:46 AM
2nd HO ALT, worth it to ground alt case -> chassis? CleanNMean General Car Audio Discussion & Questions 0 11-13-2009 07:38 PM
