What exactly happens to an amp when the outputs are shorted? - Car Audio Classifieds!
Old 01-20-2012, 12:21 PM
Wingman0121's Avatar
0/11 sssss2171
Default What exactly happens to an amp when the outputs are shorted?
Can anyone describe it in series of events?
Old 01-20-2012, 04:32 PM
0/11 sssss2429
Feedback Score: 46 reviews
Depends on the configuration of the outputs. Some short +rail to -rail which then causes the supply to draw excess current and could cause the power supply fets to fail too. This could happen without the external fuse blowing, depends on the parts used in each section.
Old 01-20-2012, 04:50 PM
mega fatty
0/11 sssss6008
Or you can blow the output fets
When it is blown it can be shorted or open
Or you can damage the gate which tells the device when to turn on and off
07 mazdaspeed3
rd d9 @ .5ohm
FS: Eclipse cd 3100 5v outputs Bushj311 Head Units, Processors & EQs 15 11-19-2011 08:25 PM
Mmats 4000.1 shorted outputs bad4health Broken & Non-working equipment 13 06-11-2011 04:02 PM
mono amp 4 speaker outputs? Wingsfreak9 General Car Audio Discussion & Questions 5 04-26-2011 07:59 PM
rcas or outputs? midnite toka General Car Audio Discussion & Questions 2 05-01-2010 10:40 AM
[SOLD] Sundown 1200d-Shorted outputs ascitiesburn69 Broken & Non-working equipment 11 12-04-2009 09:52 AM
