8 runs of wire!?! - Car Audio Classifieds!
Old 01-20-2012, 08:43 PM
0/11 sssssss65
Default 8 runs of wire!?!
I have a 01 s10 and am going to be running 4 power 4 ground from front to bank that's a overall 2.25" circular diameter and there's no way to run a conduit that size with all my exhaust gas tank and ect..and I don't want to run it bare so the only other option is to run it thru the cab and somehow tunnel it thru the blowthru I am imaging this to look really gay..so I know im not the only guy with a high current producing ride with a gazillion wires so what are some tips n tricks. Thank you
Old 01-20-2012, 08:45 PM
Me > Lord Van
0/11 sssss2831
Run them down both sides of the car? 4 on each framerail.
Team DOA
10 inches of terror
One DD 9510F + one kicker zx2500=150+ db
One Sundown SA-8 + 2 mb quart 2000's = 150+ db
-2006, 2007, 2009, and 2010 MECA World Champion
-2008 Bassrace 130-139.9 National Champion
Old 01-20-2012, 08:50 PM
0/11 sssssss65
Still too damn tight to get any conduit I have 1"
Old 01-20-2012, 08:51 PM
0/11 ssssss127
maybe you could just stick em in a long pvc pipe or pipes and run them under the car? but if the exhaust and other stuff is still a problem then I dont know
Old 01-20-2012, 08:54 PM
bigdhenderson's Avatar
0/11 sssss4981
Feedback Score: 45 reviews
run a big conduit bent around stuff like an exhaust pipe? I ran 4 runs inside one frame rail....no conduit. Gonna run the 4 runs of grounds inside the other frame rail.
Old 01-20-2012, 08:55 PM
0/11 sssssss65
Yeah just wont work.. they will all fit under no problem without conduit but how gay would that be taking the chance of it grounding out.. BBear sorry about your blown sub
Old 01-20-2012, 08:59 PM
0/11 ssssss368
Lots of people run wire under their vehicle without protection with no problems. I ran 4/0 under a Mitsubishi 3000gt with no issues
[SIGPIC][/SIGPIC]
2001 Ford expedition
New build coming soon!
Lots of cone area and lots of power
The Following User Says Thank You to notenufbass For This Useful Post:
cgriffin224 (01-20-2012)
Old 01-20-2012, 09:02 PM
0/11 ssssss368
What about the outside of the frame rail?
[SIGPIC][/SIGPIC]
0/11 sssss4981
yeah if you use good enough wire and route it smartly you should never have a problem unless you do a lot of rock crawling/off roading...And thats what fuses are for.
Old 01-20-2012, 09:04 PM
0/11 sssssss65
I was going to use exhaust stock but it was too big and wouldn't make it around the obstacles. I've used frame rails in the past however on this ride the frame is hollow but all sealed up.
2 11 ft runs of knu 12ga Karma SS speaker wire rachidfunaki Wiring, Electrical & Other Installation Equipment 0 04-02-2011 10:52 PM
purpose of multiple runs of wire? poundstone General Car Audio Discussion & Questions 36 01-25-2011 10:30 PM
Wire Runs ModFreak General Car Audio Discussion & Questions 40 06-09-2010 06:05 AM
Power Wire runs? mads10bass General Car Audio Discussion & Questions 6 04-29-2010 07:58 AM
How Many Runs Of Power Wire And What Make? duramaxxed General Car Audio Discussion & Questions 14 07-30-2009 09:07 PM
