Batteries - Car Audio Classifieds!
Old 01-21-2012, 02:58 PM
0/11 sssss1184
Default Batteries
Whats the best way to wire second batteries?
Old 01-21-2012, 03:32 PM
newarkbeast973's Avatar
0/11 sssss7810
Run positive and negative from front to back battery. Same
New build coming soon!!
Old 01-22-2012, 12:49 AM
0/11 sssss1184
2 runs of 0 right one to pos n one to neg? ive heard just one run then ground in the back, whats the difference?
Old 01-22-2012, 07:27 AM
0/11 sssss1092
No difference. As long you have a good ground to the vehicles chasis.
Old 01-22-2012, 01:48 PM
Active Member
0/11 ssssss546
^^I agree, if you have done your big 3 correctly, your vehicle should have a solid ground on the frame. I think its a huge waste of wire when I see people running several grounds front to back.
Old 01-22-2012, 01:58 PM
nicholask1993's Avatar
Dubstep Addict
0/11 sssss1802
Kinda off topic but is it really going to damage anything of you have a "regular" battery up front and an AGM battery in the back?
I've heard mixed opinions on my searching...
1998 Subaru Forester
Sony CDX GT-565UP Head Unit
Cadence 6.5" Components
MB Quart Onyx 1500.1
/Surreal
Old 01-22-2012, 02:00 PM
05TRAILBLAZER's Avatar
i ♥ Sundown Audio
0/11 sssss1946
^^ thats true!! im out of thanks
Old 01-22-2012, 02:01 PM
Matt3824's Avatar
0/11 sssss3754
Im running an interstate under the hood and 3 D3400s out back its fine
Old 01-30-2012, 07:56 AM
0/11 sssss1184
Another question on batts. My spring build=all 0 ga, big 3 in 0 ga, audiopipe 3000 and 2 hdc3 15s. Stock batt in the front and i have a kinetic 1400. Do i need more batts, n if so how much?
Old 01-30-2012, 08:02 AM
0/11 sssss7810
Either more batteries or 1 bigger one!!
2 batteries? Scrapmanson General Car Audio Discussion & Questions 14 03-28-2011 12:57 PM
[SOLD] Huge Batteries "8d" Energy Power Commercial batteries Josh Wahlie Wiring, Electrical & Other Installation Equipment 40 09-09-2010 10:55 PM
batteries! 1lownissan Wanting to Buy (WTB) 2 05-22-2010 02:08 AM
Need batteries Juice0723 Wanting to Buy (WTB) 0 05-12-2010 12:52 AM
Mixing wet batteries, and Dry batteries. hornedfrog1985 General Car Audio Discussion & Questions 0 09-22-2009 08:49 PM
