300zx electrical problem - Car Audio Classifieds!
Old 01-22-2012, 03:30 PM
0/11 ssssss122
Default 300zx electrical problem
ok my brother had a problem with his 300zx. he recently installed a old school re xxx 15 in it and running it at 1200w. he has a stock alt and a redtop battery. he was driving on interstate 75 and his car started to die on him. and would give it gas and it would keep jerking and still pushed but he had to get it towed back home. he has a brand new redtop so it cant be the bat. i told him its the alt and he think so too. but the thing is he needs a alt that can handle the amperage from the amp. he doesant have alot of money to spend for a dc,mechman and big names like that. i was just wondering he anyone could give me a good reliable brand alt i can tell him to look into.
Old 01-22-2012, 03:38 PM
0/11 sssss1868
I've seen some positive reviews about Powerbastard alts. Also check into local rebuilds... I can't imagine he'll need very much alt for 1200 watts.
Old 01-22-2012, 03:39 PM
oslouie's Avatar
0/11 sssss5073
Feedback Score: 69 reviews
Guessing will cost you a lot of money in the longrun. Take that alt out and have it tested first.
The Following User Says Thank You to oslouie For This Useful Post:
schmiddr2 (01-22-2012)
Old 01-22-2012, 03:54 PM
Zooook's Avatar
1337 M3mb3r
0/11 sssss3991
Feedback Score: 31 reviews
If it's the alt than the battery light should come on. If I were him check stock alt if it's bad get a new one it doesn't have to be a h/o alt just stock and do big 3... I believe the way to test to see if the alt is bad than while the car is running disconnect the negative on the battery and if the car dies than alt is bad. I think that's how atleast or you could pull it and have it tested.
ALL FOR SALE ALL FOR SALE PM ME FOR PRICES
2003 BMW 330I
2x12" AB HD/W DC XL recones
Old 01-22-2012, 04:06 PM
Veteran Member
0/11 sssss3359
I run db electric alt. As far as gm products go best bang for the buck. 250 amps are under 300 shipped. Not sure if they make them for Nissan. You'll have to check into that
Old 01-22-2012, 04:10 PM
0/11 ssssss577
start the car and check voltage with a dmm...... if you have yet to try this your waseting your time , a red top should be in the 13,5 rage while off(i could be wrong) running you should be at or over 14v , 300zx's are picky *****es anything could cause it to work poorly,what year is it?
Old 01-29-2012, 11:29 AM
0/11 ssssss122
it is a 1990
Voltmeter issure/Electrical problem? joshua1davison General Car Audio Discussion & Questions 0 09-18-2011 07:52 PM
2001 mazda protege electrical problem, help! Ryan1126 General Automotive Chat 2 05-19-2011 11:10 PM
Electrical problem? Big 2/3, 3 batts. And lights/ACC is flickering when cars on?? AuZy_AuDiO General Car Audio Discussion & Questions 8 04-08-2010 02:07 PM
Need help diagnosing electrical problem. RE_Gawker General Car Audio Discussion & Questions 11 12-04-2009 11:07 AM
Just got a 300zx vellocet General Car Audio Discussion & Questions 26 07-25-2009 09:26 PM
