Amp won't turn on - Car Audio Classifieds!
Old 01-22-2012, 10:51 PM
0/11 ssssss154
Default Amp won't turn on
I bought a Kicker 450.2 for $20. He said it was stuck in protect but when I bought it, it wouldn't even turn on. It doesn't look like anything is wrong with it, but who knows. I'll post a picture of the guts tonight but does anyone have any ideas for troubleshooting? When I looked it up on Google I didn't really get much help.
Old 01-22-2012, 10:58 PM
Bologna's Avatar
Ad ministrator
0/11 sssss2872
So the amp doesn't go into protect mode?
Refs: BlackWaterOp x2, Master69 x3, Scottie x3, RidnClean, JusBlaze (Scammed Me), SPLaudio x3, ltr450racer690, dbeez, LuisT, SPY, Mgcauctions09 x3, pieper88 x3, scottyk, Jh8909, JB312, stretch, Mechman, 01SpyderDB23, andrewtexas123, 50 black guys, bubbagumper6, btr, SacTownBully84
Old 01-22-2012, 11:03 PM
0/11 ssssss154
It doesn't do anything at all. I unplugged the amp I'm using now and plugged this one in and nothing happened. The power light doesn't turn on or anything. Then I plugged my other amp back in which still worked fine.
Old 01-22-2012, 11:04 PM
0/11 ssssss154
Now that I think about it I should have tried playing music I guess. But I tried turning it on last night but it didn't work that way either.
Old 01-22-2012, 11:06 PM
0/11 sssss2429
Feedback Score: 46 reviews
Pics of the amp inside and we can get you some points to measure if you have a meter.
You may need to post some closer shots later.
Sent from my Punch 60.2
Old 01-22-2012, 11:08 PM
0/11 ssssss154
Cool, thanks! Will do.
Old 01-22-2012, 11:10 PM
Prohibited Sellers/Buyers
0/11 ssssss429
In order to do some amp diagnostics u will need a multimeter
Usually amp won't power on when there is something wrong electrical and is shutting off to prevent further damage.U did good tho at 20 bucks even if u can figure whats wrong with it u can always turn around sell for 20 or more.Will recommend u to read basic car audio repairs before u go any further .modern amps have high voltage power supplies so a mistake can be costly
Old 01-22-2012, 11:29 PM
0/11 ssssss154
That's what I figured when I bought it. I do have a multimeter but I'm not entirely sure how to use it. If I go to use it I will definitely make sure to look up how, though.
Old 01-22-2012, 11:40 PM
0/11 ssssss429
post a picture as the others said ,step by step we can make it happened .Few heads are always smarter than one
Old 01-22-2012, 11:54 PM
Dman3047's Avatar
CACO Fanatic
0/11 ssssss789
Feedback Score: 32 reviews
Check the fuses.
2009 Chevrolet Malibu
Head Unit: iPad
Front Stage: 4 Sundown Neo-Pro 8s/4 Sundown Neo-Pro 6.5s
6 Selenium ST200s
Subs:
Sub Amp: Hopefully a SAZ 3500 or 4500
Front Stage Amps: SAX 200.4/SAX 125.2
Batts: XS Power D3100
Wire: Audio Technix
My amp makes noise when i turn off power Dirtbikerrob General Car Audio Discussion & Questions 12 08-28-2011 01:12 AM
Amp Popping when you turn amp on and off KAPONE.SS General Car Audio Discussion & Questions 2 09-14-2010 10:02 AM
hooked up everything amp won't turn on gbo559 General Car Audio Discussion & Questions 32 11-20-2009 11:43 PM
amp wont turn on csu87 General Car Audio Discussion & Questions 7 07-23-2009 03:36 PM
AMP Willn't turn off Dadowhip08 General Car Audio Discussion & Questions 15 07-22-2009 09:13 AM
