General Questions - Car Audio Classifieds!
Old 01-23-2012, 01:00 PM
garygross7's Avatar
0/11 ssssss305
Default General Questions
I have a Ford 2000 Explorer and am thinking about going with 2 Skar VVX 12's. If I push them at 2k rms, would I need a h/o alternator or just some extra batteries? I might go with one though. Any suggestions on amps to run them on? And I am looking for some good 6x8's to replace my current door speakers.
Old 01-23-2012, 01:04 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
you might be able to find a good used rockford 1500bd amp or sundown 1500d for pretty cheap. they are great amps that you would be happy with. i ran a sundown 2500 with stock alt and just a single batcap2000 in the rear on a single 12" and pounded it all the time with no issues. so i would say just some extra batteries would suffice with the power you are planning.i would do the big3 in 0 gauge and run 0 gauge throughout.
My game is legit,
Old 01-23-2012, 01:10 PM
garygross7's Avatar
0/11 ssssss305
well i would probably go with a skar sk1500-d. but at 2ohms it would just be 1k rms and at .5 ohm i don't know what it would push
Old 01-23-2012, 01:31 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
you would probably see less than 1k with box rise. i am currently running a 4k amp, ho alt,3 batteries, 1-18" sub wired to 1 ohm and at last show i clamped 1668w at 4ohms with box rise.
My game is legit,
Old 01-23-2012, 03:11 PM
garygross7's Avatar
0/11 ssssss305
Ok thanks. I think I'll go with just one and some new door speakers. And a second one farther down the line when I get a new ride.
Old 01-23-2012, 03:27 PM
oslouie's Avatar
0/11 sssss5073
Feedback Score: 69 reviews
You need to build a more efficient box.
Old 01-23-2012, 03:33 PM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
good rule of thumb is for every 1k watts rms u need roughly 70amps of course depending on the application.....you can run 1500rms or 2krms on stock charging system because with rise im sure u wont be putting out 2krms to them subs but its just a piece of mind thing for me and preventing something from going poof....MOAR POWA
Old 01-23-2012, 04:19 PM
garygross7's Avatar
0/11 ssssss305
Yeah my stock alternator is only 140 amps. I'll go with one 12. Don't want to invest too much in it when the car has a lot of miles.
Old 01-23-2012, 04:34 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Nope. Had a bigger box and did 150+db but wanted a box tuned way low(30 hz)for music. I knew it would kill my score but I don't care. I still do almost 149 db @51 hz
My game is legit,
Old 01-23-2012, 05:00 PM
05TRAILBLAZER's Avatar
i ♥ Sundown Audio
0/11 sssss1946
box rise sounds right
General Survey: headshok (Shok Ind) 6 09-15-2011 03:05 PM
Just in general e2theloc General Car Audio Discussion & Questions 9 02-24-2011 09:52 PM
