deck cutting out... - Car Audio Classifieds!
Old 01-23-2012, 11:49 PM
0/11 sssssss24
Default deck cutting out...
Having problems with my deck cutting out when my subs are hitting. Only on high volume. They are cutting out to the point where subs playing good but theres no words.
My system consists of a JVC kx810 double din, kicker components, jl tweets, audioque 2200, and 2 15" dl lvl 4 xls. Is it a power loss issue or what? It did this with my previous deck but the stereo was much smaller?
Im not a pro at this but I know a little bit.. any input appreciated! thanks
Old 01-24-2012, 12:03 AM
05TRAILBLAZER's Avatar
i ♥ Sundown Audio
0/11 sssss1946
so your whole front stage just gives out/doesnt play no more just subs?
Old 01-24-2012, 12:04 AM
Bologna's Avatar
Ad ministrator
0/11 sssss2872
Do you have an amp on your speakers? Or just your subs?
Refs: BlackWaterOp x2, Master69 x3, Scottie x3, RidnClean, JusBlaze (Scammed Me), SPLaudio x3, ltr450racer690, dbeez, LuisT, SPY, Mgcauctions09 x3, pieper88 x3, scottyk, Jh8909, JB312, stretch, Mechman, 01SpyderDB23, andrewtexas123, 50 black guys, bubbagumper6, btr, SacTownBully84
Old 01-24-2012, 12:03 PM
0/11 sssssss24
yea, the rear stage goes first and then as you turn it up the front stage goes.
Old 01-24-2012, 12:04 PM
0/11 sssssss24
amp on just the subs for now. i do have an amp for my speakers i just need to find time to wire everything...
Old 01-24-2012, 01:12 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
my friend had this problem, until he put his speakers on an amp.
Add an extra ground on your headunit, and how low does your voltage dip when you have everything turned up?
Old 01-24-2012, 01:20 PM
jmelton86's Avatar
Something clever.
0/11 ssssss626
Too low of voltage at HU (due to too small of power/ground wiring or bad connections) or too low of an impedance wired to the channels on the HU.
CDA-9855 PDX4.100 GTO14001
Tuning low is great.
KeepItSimpleStupid
Old 01-24-2012, 04:20 PM
0/11 sssssss24
ok thanks for the input! so i will just disconnect current ground from deck and make my own with a thicker gauage wire?
also my voltage dips pretty low. i have a hc2400 battery i need to hook up.
Old 01-24-2012, 04:22 PM
Matt3824's Avatar
0/11 sssss3754
Just go ahead and run your speakers to the amp if you're gonna go in there working on it. Why waist time on some thing that will just get redone anyway IMO
Old 01-24-2012, 05:07 PM
0/11 sssssss24
Yea I might as well... Also does anyone know any good links on hooking up a 2nd battery?
amp cutting out Koteman General Car Audio Discussion & Questions 8 11-09-2011 05:52 PM
Amp cutting on and off? oonegro General Car Audio Discussion & Questions 0 02-01-2011 05:03 PM
Subs cutting off davidrforbus General Car Audio Discussion & Questions 17 05-29-2010 07:32 AM
WTB Touchscreen Deck or high voltage deck stunnaboiBMG Wanting to Buy (WTB) 8 04-17-2010 11:06 PM
cutting fat jagblazer01 Sports and Fitness 2 04-29-2009 04:48 PM
