2nd baterry install need help !! - Car Audio Classifieds!
Old 02-28-2012, 02:57 PM
0/11 ssssss338
Default 2nd baterry install need help !!
Hello everyone new guy here LOL I have a big problem that I can't figure how to fix I installed a new optima batt in my trunk and the circuit breaker keeps going off , I installed everything correctly its just that one problem I'm having if anyone can help I would appreciate the help, thanks in advance and just to let everyone know the amp is a ma audio hk10ka.
Old 02-28-2012, 03:01 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
I'm sorry to say this. But if you are only running 2 batteries on that amp you are asking for trouble.
The reason you are probably popping the breaker is cause 1) you are drawing more current then its designed for(most are good for 200A) or 2) you have the positive and negative backwards.
Old 02-28-2012, 03:10 PM
oxsign's Avatar
0/11 sssss1876
Ditto, that's a power hungry amp. What alt are you using with the 2 batts?
1971 VW Fastback
Old 02-28-2012, 04:17 PM
0/11 ssssss338
Thanks guys I was afraid someone was gonna say that I need more power, I'm running stock alt with 2 optimas a red top for starting and my new yellow top in the rear , so I guess its I get a Ho alt or sell the amp I feel like I real noob I should have known better.
Old 02-28-2012, 04:20 PM
Matt3824's Avatar
0/11 sssss3754
Yea I'd say an HO alt and 2 more optimas in the back MIGHT give you enough power behind it.
2nd Try etznova Competition Corner 16 04-03-2011 10:35 AM
Clean install vs Loud install linden General Car Audio Discussion & Questions 32 12-23-2010 05:55 PM
Should i consider a 2nd batt? bwe45 General Car Audio Discussion & Questions 2 08-13-2010 10:18 PM
Ok 2nd time around!! BigC-Expo Off Topic Chat 1 12-22-2009 08:18 PM
