Building a MONSTER sub - Car Audio Classifieds!
Old 02-29-2012, 08:05 AM
XORstatus's Avatar
0/11 ssssss552
Arrow Building a MONSTER sub
I am in the process of building my first subwoofer. It will be a frankenstein.
My real question is voice coil configuration.
Im hesitant to make a decision on dual 2 or dual 4.
SO that i can be ran at 1 or 2 ohm.
What are the greater proportion of 2kw amps stable?
Im just trying to think about the future and the ease of producing watts.
Old 02-29-2012, 08:24 AM
Matt3824's Avatar
0/11 sssss3754
Go dual 2. There are far more amps in that range that do full power at 1 ohm. The list for 2 ohm at that power is pretty short.
Old 02-29-2012, 08:28 AM
jmelton86's Avatar
Something clever.
0/11 ssssss626
If you can find a dual .5ohm coil, go that route. Wiring the coils in series will yield more Bl.
CDA-9855 PDX4.100 GTO14001
Tuning low is great.
KeepItSimpleStupid
Old 02-29-2012, 08:36 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Will the coils be round wound or flat wound? Are you gonna use aluminum or copper? What kind of former do you plan on using? How many and what kind of spiders are you going with? What motor are you using? Will they be 2 layer,4 layer,8 layer, etc....?
Old 02-29-2012, 08:40 AM
1/11 ssss31258
dude.. just let him do the sub. he's concerned about the impotence.. not much more than that for now.
dual 2 is good shit.
XORstatus's Avatar
0/11 ssssss552
YOU HAVE MANY QUESTIONS. lol
I bought an MTX 9500 motor so that is locked in.
However all other variables are still up in the air.
Which choice is superior?
Flat vs round windings?
Copper vs aluminum?
4 layer vs 8 layer?
At this point i am very open
Old 02-29-2012, 08:49 AM
Ja Marcus
0/11 sssss6975
I just am listing things you should think about. All of them have an effect on how the sub will perform. As far as one being superior it has more to do with how you want the sub to perform. Some have advantages over others in certain aspects. Will it be more for daily or SPL?
1/11 ssss31258
flat aluminum. {choice for weight and capacity}
layers don't matter much. (personal opinion based on the fact a 4 layer coil can be made of larger material and has more capacity) but I'm sure someone will argue with me on that.
if you can get a TC cone and coil collar, that would be good. The cones aren't the greatest thing ever but they are designed to work with the basket you want and move far. {figure out how to reinforce the center of the cone so it doesn't dent and you'll be golden}
other options;
robot underground had some high roll 18" cones. not sure if they do now though.
bigdhenderson (02-29-2012)
Old 02-29-2012, 08:52 AM
vince79vette's Avatar
0/11 sssss2011
Copper vs aluminum?
4 layer vs 8 layer?
Flat winding and alum for more power handling and as for 4 or 8 layer how much power do u want to send to it
Old 02-29-2012, 09:10 AM
Ja Marcus
0/11 sssss6975
Really he needs to know the gap before he can choose the windings he may only be able to fit a 4 layer(not sure what the 9500 gap is). Also the winding height will need to be taken into consideration as well.
The Following User Says Thank You to audioarsonal For This Useful Post:
thorshammer (02-29-2012)
How to go about building sub? SPLpizzaguy General Car Audio Discussion & Questions 4 08-24-2011 02:07 PM
need help building my first sub extremechevyman67 General Car Audio Discussion & Questions 12 02-13-2011 10:57 AM
Building up sub Dunbar91 Off Topic Chat 13 11-22-2010 09:47 PM
Building A Sub PhishHead General Car Audio Discussion & Questions 13 10-12-2010 01:08 PM
building of a sub nuboot Team Teamless 17 04-30-2010 12:15 AM
