Where to tie into fuse box?! - Car Audio Classifieds!
Old 02-29-2012, 04:25 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
Default Where to tie into fuse box?!
I'm installing my singer alt and don't know where to put my add a fuse in my 2010 tahoe, has to be something that turns on and off with the ignition like a remote. please help!
Old 02-29-2012, 04:45 PM
Matt3824's Avatar
0/11 sssss3754
Go under the dash with a dmm and turn the key on and off with each wire. The12volt.com can be helpful sometimes.
Old 02-29-2012, 05:17 PM
Ryan1126's Avatar
0/11 sssss9178
well unfortunately which ever one i use. it has to be under 10amp. which leaves me very few choices.
Old 03-02-2012, 10:32 AM
Matt3824's Avatar
0/11 sssss3754
Why does it have to be under 10 amp? I would guess that the trucks ignition wire would be less than 10 amps
Old 03-02-2012, 10:51 AM
0/11 ssssss226
on the 2010 tahoe if you want to find a switched wire you can grab one from the bcm but you must use a relay as this wire wont supply much current. same goes for the ignition harness im pretty sure they are all light gauge wires that you dont wanna tap into
Old 03-02-2012, 11:00 AM
Veteran Member
0/11 sssss3359
Any 10 amp fuse should work. I've had my duals running fine for a year
Old 03-02-2012, 12:07 PM
0/11 ssssss226
Green plug Brown or Pink wire on the top of your bcm (located left hand side underdash) will be switched test with dmm to confirm. this will only suport enough current to tigger a relay.
then grab constant from behind the panel on the left side of the dash. this will allow you to power any load that needs to be switched up to 10 amps.
Other wise just use a fuse tap in a switched fuse location and grab your power from the unfused side
f/s; new '04-'10 nissan titan tie-down cleats, set of 4 Nudels Miscellaneous Stuff For Sale 3 01-10-2011 03:11 PM
White Tie Affair? Any words on the band? its_ray_ray Off Topic Chat 1 06-18-2010 06:58 PM
159.9 Bassrace tie 98AckCL23 Off Topic Chat 2 05-19-2010 06:55 AM
Battery tie-downs zlibby76 General Car Audio Discussion & Questions 5 03-28-2010 11:39 PM
[SOLD]Energy Suspension Polyurethane Tie Rod End Boots - BNIB toolguy420 Miscellaneous Stuff For Sale 1 08-19-2009 08:17 PM
