Experience with a 3000gt? - Car Audio Classifieds!
Old 03-01-2012, 09:08 AM
0/11 ssssss247
Default Experience with a 3000gt?
I am wanting to put a sub in my 3000gt, and I was wondering if anyone knew the best placement for it in the back hatch? It's going to be 1 8in woofer ported. Where should I put the box and what direction should I point the sub and the port? Thanks!
Old 03-01-2012, 09:17 AM
0/11 ssssss160
i know its not a 3000gt, but i put 2 12s in my buddies probe subs up port passenger side and it was pretty ridiculous for only 500ish watts
Old 03-01-2012, 09:22 AM
0/11 ssss31258
depends on the sub and power you have.
Old 03-01-2012, 09:25 AM
0/11 ssssss247
sa-8 v.2 with a saz-1500 at 2 ohms
Old 03-01-2012, 09:34 AM
0/11 ssss31258
fire the sub at the window and fire the port into the passengers side rear corner. {leave 6 to 8" of clearance between the port and the corner}
this recommendation is for a cube box with and external port
Old 03-01-2012, 02:20 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
I was going to recommend the same thing. 8" enclosures are very difficult lol
Old 03-01-2012, 02:35 PM
0/11 ssssss247
Why an external port?
Old 03-01-2012, 02:44 PM
0/11 ssss31258
because SA8s like about 0.80 cu ft of air with a 4" port about 34" long {approx 33.5hz}
but... a 4" port 34" long won't even fit in .8 cu ft.
you can use a smaller box and the port will get longer. Or you can use a larger box and the port will get shorter.
I haven't tried a larger box yet because the specs didn't warrant it. I can tell you on the same total power, four are about the same output as two in the same size box and tuning.
Last edited by iamsonic; 03-01-2012 at 02:47 PM. Reason: wrote that wrong didn't I
Old 06-10-2012, 06:38 PM
Brand New Members
0/11 ssssssss3
In my 3000 I have to 12 kicker cv's I'm an enclosed box. I folded the back seat down and pointed those babies to the hatch. I'm sure by. Now you found that pointed that way it bumps so hard. Keep onind that in the. Back from the carpet to the lowest part of the hatch its ten. Inches.
Old 06-10-2012, 06:39 PM
Brand New Members
0/11 ssssssss3
One other thing on the hatch take. The panel off and dyno the shit out. Of It. Well worth it.
2 x ShOcKeR Sig 18's in 3000gt TreyGT Uninterrupted Build Logs 17 10-13-2011 03:32 PM
1997 Mitsubishi 3000gt alt quote notenufbass General Car Audio Discussion & Questions 3 12-26-2010 11:43 PM
Any experience with these? basshead08 Team Teamless 15 03-23-2010 03:29 PM
1996 Mitsubshi 3000gt Speaker box specs nipples09 General Car Audio Discussion & Questions 3 01-21-2010 03:20 PM
my DC experience Violence* (DC) 24 12-30-2009 10:59 PM
