Stinger Voltmeter showing different Voltage then actual? - Car Audio Classifieds!
Old 03-01-2012, 08:37 PM
30Hertz's Avatar
0/11 ssssss137
Default Stinger Voltmeter showing different Voltage then actual?
Whats goin on people,
So heres the deal. I've had my Stinger Volt Meter installed for a while and never really noticed a problem albeit I didn't really compare the voltage at the battery, vs the voltage at the amplifier with a handheld DMM vs the Stinger Volt Meter.
However after I installed my Mechman 220 amp adjustable voltage alternator, I've been doing some testing while setting my voltage and have come across this issue.
I've got my Stinger Volt meter installed as follows:
The Volt meter remote is patched into my amplifier REMote wire. The positive and negative leads are placed into the Orion 2500d positive and negative terminals along with the wire from the battery ( I did this so I would see the voltage at the AMP to monitor the voltage drop.
Lately while I've been driving, Ive been noticed inconsistent fluctuations in the voltage. Sometimes, the voltage would ready as I had set it 14.4v and other times at a stop it would hover around 10.9 to 12.1.
I thought this was weird so I did a little investigating with my True RMS DMM.
  • I started off at with the truck off, with the DMM the Battery read good at 13.1v. Inside the truck, the Stinger VM read at 12.1v
  • Truck on, with the DMM the battery checked good at 14.8v. , Inside the truck, Stinger read at 13.1v
Ok, so I thought maybe..just maybe I was getting some voltage drop from the battery back to the amplifier.
  • I checked with the truck on, used my DMM and checked the terminals on the amplifier and it checked good at 14.8v however inside the truck, the Stinger was still reading between 13.1v and 13.7v.
I figured this was rather weird and was wondering if anyone has had this issue before? The whole point of having my Stinger Volt Meter installed was to get an accurate reading as to what the actual voltage was at the amplifier. With my troubleshooting today, I'm not having any faith in the readings I'm getting inside the cab while driving.
Any ideas?
Thanks Gents
-30
Old 03-01-2012, 08:51 PM
r1 banshee's Avatar
<-- all I need
0/11 ssssss288
take the cover off the meter, and adj the pot to read as same as your DMM. Also hook it to your pos side of amp, this will show you what your amp is seeing
Subs: 2 9515's super charged
Amp: DD M4a w/Toolmaker duel inputs ,
Highs: DD CXS 6.5 (burp car)
4 kinetik hc3800, 4 run's of 1/0
The Following 2 Users Say Thank You to r1 banshee For This Useful Post:
30Hertz (03-01-2012), iamsonic (03-01-2012)
Old 03-01-2012, 08:57 PM
qopiyu's Avatar
0/11 ssssss531
Banshee is right, the volt meter needs to be set to the voltage you have to read accurately.
Old 03-01-2012, 09:53 PM
30Hertz's Avatar
0/11 ssssss137
Thanks guys, like a newb I didn't even realize I could match it..durr durr...
Banshee,
I've got it hooked up to my amp currently but I also have the ground going to the ground terminal on the amplifier, do I need to keep it that way or ground it to my grounding block?
Thanks!
30
Old 03-01-2012, 10:13 PM
r1 banshee's Avatar
<-- all I need
0/11 ssssss288
Banshee,
Thanks!
30
Whats ever is easier makes no difference.
Stinger Digital Voltmeter LowLyfe General Car Audio Discussion & Questions 3 11-01-2011 08:03 PM
Blue Stinger Voltmeter Josh_Berkhimer Wanting to Buy (WTB) 1 08-05-2011 09:36 AM
stinger voltmeter?? fyerbyrd22 General Car Audio Discussion & Questions 16 06-01-2011 12:07 AM
want stinger voltmeter Juice0723 Wanting to Buy (WTB) 3 05-24-2010 02:50 AM
Stinger Voltmeter Voltage Drop crownvicon26's General Car Audio Discussion & Questions 16 01-08-2010 05:14 PM
