Closed cell foam - Car Audio Classifieds!
Old 03-01-2012, 10:48 PM
0/11 ssssss123
Default Closed cell foam
I was sitting here thinking of ways of doing things. Now, no way am I a pro at this, it is just a thought that popped in my head. So I pulled out the laptop and starting doing some searching. I'm looking to add another layer on top of the damp pro I have on the doors, to help to have the Polks perform and sound a little better. Is all CCF the same? I started searching and found that it can get pricey quick especially if I want to cover every door on my car and the ole lady's car. How would this work as a substitute say to the other sound deadners CCF. IE dynamat, second skin etc etc etc
Volara Closed Cell Foam, Padding, Sheet Foam Rubber, Poker Table Foam
Old 03-01-2012, 11:04 PM
0/11 sssss1250
Feedback Score: 34 reviews
decide on what you want to do exactly first. sounddeadenershowdown.com
SPL-Lab REP
Want an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has more features and more support? PM me.
The Following User Says Thank You to slim2fattycake For This Useful Post:
schmiddr2 (03-02-2012)
Old 03-02-2012, 01:19 AM
schmiddr2's Avatar
ΞΞΞΞΞΞΞΞΞΞΞΞΞΞΞ
0/11 ssssss428
I agree with slim. Decide what kind of treatment can be added to what you already have and will do what you want.
#1. Prevent wave cancellation.
#2. Make sure the sound waves from the front of the driver are not hindered by the door panel.
Old 03-02-2012, 01:27 AM
SPLpizzaguy's Avatar
Humbled by CACO
0/11 sssss3111
Feedback Score: 57 reviews
Check out raam audios liner. I have a lot in my malibu. Its pretty cheap as well. I covered all of my deadener in it and it is almost silent in my car
4 sa10s
Taramps 8k
4 American Bass VFL 6.5s
Ohio Generator 305 amp alt
4 Vifa Tweets.
Old 03-02-2012, 08:40 AM
0/11 ssssss123
What I am looking to do is cut down on some of the buzzing from the door panel, and to quiet the cabin of the cars a little
Old 03-02-2012, 11:10 AM
Second Skin Rep Jon's Avatar
Vibration Consultant
0/11 ssssss412
If you're just trying to eliminate the buzzing and rattling, that can easily be remedied with the product you provided a link to.
Two tips though.
1. I would suggest looking for a product that is more waterproof/resistant for use in a vehicle.
2. Depending on the grade and quality of the Volara, it may have a high compression set. In other words overtime it may go "flat" from being installed between the door panel and sheet metal.
Have a question about
? Shoot me an
Old 03-02-2012, 11:17 AM
schmiddr2's Avatar
ΞΞΞΞΞΞΞΞΞΞΞΞΞΞΞ
0/11 ssssss428
Read Sound Deadener Showdown - Your Source for Sound Deadening Products and Information
"When trim panels buzz or rattle, lining them with CCF will isolate them from whatever they are rattling against. Problem solved."
For some reason the Second Skin Audio website is not working but they sell similar products as well, shop around.
Old 03-02-2012, 11:26 AM
0/11 ssssss412
FYI, we're doing some maintenance on the site.
? Shoot me an
Old 03-02-2012, 11:30 AM
KTMrida4life's Avatar
0/11 sssss2271
Feedback Score: 33 reviews
So if I wanted to fix my rear deck/door panels vibrating, where can I get some good cheap CCF? Not looking to spend a fortune.. like the OP said, it gets pricey quick. Everywhere Im putting this stuff is already "treated" with AT 60
Old 03-02-2012, 11:36 AM
0/11 ssss31258
yeah.. links are great.
second skin site is down
w w w . s o u n d d e a d e n e r s h o w d o w n . c o m
works just fine though.
other than that, I saw some CCF mat for rugs a Lowes for cheap.. a little thick.. like 5/16".. but at 24-30" wide and $4ish per linear yard, it seems like a decent option.
Wet cell & dry cell Dhern409 General Car Audio Discussion & Questions 0 02-06-2012 10:21 PM
Expanding foam? andrewtexas123 General Car Audio Discussion & Questions 11 04-22-2011 12:12 AM
expanding foam korey_hofer Off Topic Chat 10 12-27-2010 09:32 PM
Why Foam surrounds? FAUEE General Car Audio Discussion & Questions 6 09-02-2010 09:48 PM
spray foam? Bob Saget General Car Audio Discussion & Questions 16 05-04-2010 02:13 PM
