200 amp alternator help! - Car Audio Classifieds!
Old 03-02-2012, 07:25 AM
0/11 sssssss69
Default 200 amp alternator help!
I just put a 200 amp alt in my suburban which had a stock 105 in it before. my queztion is my stock alt idled at a higher voltage? I had my alternatorrebuilt so everything is the same as stock(pulley). As soon as i hwithit the gas my votage jumps up. Ive done the big 3 with 4ga but i left the stock wires in place. My question is why does my battery still die on me? Its a deep cycle marine batt(105 amp hr). Only thing that makes sense is i only drive about 5-10 minutes one way to work. Imrunning a brz1200.1 wired at 1ohm and a r.f.300.4 Any help would be appreciated. Thanks!
Old 03-02-2012, 08:10 AM
0/11 sssssss69
Do i need to run my truck longer, run 1/0, get a smaller pulley for my alt? im lost here.
Old 03-02-2012, 09:26 AM
0/11 sssssss69
guess ill just get an undersized pulley and redo the big three with 1/0 wwire and see what happens
Old 03-02-2012, 09:28 AM
Wildbillpb's Avatar
0/11 sssss1294
Try putting that battery on a charger then stick it back in. What does the battery read when car is off?
Build Log:
Team DC Audio
Originally Posted by 1loudyukonxl
o ya i have you all beat i put a pic of sundown 200.4 amp guts on my girls back wile were doin doggie style for motivation
Originally Posted by AudioXtremes
I put an actual 200.4 on your girls back when I **** her.
Old 03-02-2012, 09:38 AM
0/11 ssssss532
possibly the rebuild wasn't successful and isn't charging properly or you have a short in the system draining the battery when the vehicle is off
0/11 sssssss69
i tryed to check it with my dmm but it took a shit on me so ill have to get a new one. i took the batt to advance auto and they charged it so idk. its not very old maybe 7 or 8 months old it was my reserve battery outta my boat and i never had to use it so maybe ill just buy me a new one.
Old 03-02-2012, 09:57 AM
Wildbillpb's Avatar
0/11 sssss1294
What kind of car? Is it computer regulated voltage? Who built this alt?
Build Log:
Team DC Audio
Old 03-02-2012, 10:10 AM
0/11 sssssss69
ill buy me another dmm check everything charge my batt redo all my connections and let you all know what happens thanks
Old 03-02-2012, 07:24 PM
jnknzz's Avatar
0/11 ssssss190
You need a smaller pulley to get more out of it at idle.
Higher overall amp rating = less idle amp rating (generally)
Factory alts put out most of their amp rating at idle.
Old 03-02-2012, 07:42 PM
0/11 sssssss69
ok thanks that answers my question . I was told that i would get more amperage at idle from a higher output alt so i was a little confused, but i kinda figured that with the bigger windings, so i just wanted to make sure before i switched to a smaller pulley
200 amp alternator davecubs14 Broken & Non-working equipment 7 02-09-2012 08:31 PM
[FS] H.O. alternator 200 amp- 4.3l blazer and more Bushj311 Wiring, Electrical & Other Installation Equipment 11 06-02-2010 01:38 PM
FS:200 amp alternator Hirschblazin Wiring, Electrical & Other Installation Equipment 12 12-18-2009 05:14 PM
200 amp/150 amp idle chevy/gmc alternator dual rectifier jdubbau Wiring, Electrical & Other Installation Equipment 0 03-09-2009 12:57 AM
Powermaster 200 amp alternator!! teamsubgopoof Wiring, Electrical & Other Installation Equipment 16 01-28-2009 10:29 PM
