Electrical problem - Car Audio Classifieds!
Old 03-02-2012, 03:28 PM
treylittlefield's Avatar
0/11 sssss5201
Feedback Score: 37 reviews
Default Electrical problem
So hot my voltmeter ran to my amp. Setup is 2 3500ds, 3d1600s, and 2 300 amp16v alts. At idle in park the voltage will jump from 18.5 to 19.5 and anywhere between. In drive sitting still it dips to 18v, volume at 0 on radio. Driving it will level out around 18.9 and stay steady no matter what. Could it be the regulator?
Sent from my C771 using Tapatalk
2000 2dr Blazer
Old 03-02-2012, 03:32 PM
skinnyg's Avatar
0/11 ssssss828
sure it isnt an adjustable one and its adjusted too high, you have an external reg? need more info
Old 03-02-2012, 03:50 PM
0/11 sssss5201
It is adjustable and external. The blue finned one. It says 12v no the regulator but it can be used for 16v I suppose, thats what they sent. I've ran this getup before with no issues, but with the new install its acting up
2000 2dr Blazer
Old 03-02-2012, 03:54 PM
skinnyg's Avatar
0/11 ssssss828
my need just readjusted, you need to check voltage out at your alt with a good multimeter like a fluke, and like I said some voltmeters are adjustable and need set with a multimeter
Old 03-02-2012, 04:10 PM
0/11 sssss5201
Also they are dual alts, at the alt they jump around too. Of course I can't check it while driving
2000 2dr Blazer
Old 03-02-2012, 04:36 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
It may be the regulator or you may have a bad diode causing inconsistant voltage. Have you tried disconnecting one alt and see if its isolated?
Old 03-02-2012, 06:53 PM
0/11 sssss5201
Gonna try the regulator.if that don't work I'll try the alternators. The bottom one is a pain to get to.lol
2000 2dr Blazer
Old 03-02-2012, 07:00 PM
TeamNemesisVance's Avatar
0/11 ssssss400
my dual alts with the transpo regulator was doing the same thing and i found it to be that the ground and positive from the regulator both need to go strait to the back of the alt not one of the batteries also have seen wire size cause this same problem before on these.
2011 SPRING BREAK NATIONALS IdBL ADVANCED NO WALL 2 CHAMPION
153.4 on music at 45hz/SUB BOX and CENTER CONSOLE by SBC (SCOTT BOWMAN CUSTOMS)
Alpine iva-d100 dvd headunit
6 Sundown SA12s
2 Sundown 3500
rockford P450.4
rockford P325.1
Diamond hex components
2 Punch P1 8s for midbass
dual Powermaster 200 amp alternators on custom bracket made by me
9 batteries (7 datasafe hx300s in the rear and 2 Optima blue tops up front)
lots of 1/0 and some 4/0 welding cable
Old 03-02-2012, 07:22 PM
0/11 sssss5201
See mine is ran to 12v. Only field wire is on the alt. So your saying field and positive go straight to alt. And ground to alt case ? So not to the batts in the back?
2000 2dr Blazer
Old 03-02-2012, 07:27 PM
Ja Marcus
0/11 sssss6975
Yes the regulator needs to see the same voltage. I ran straight off the alt to a relay that was switched 12v.
Unique Electrical Problem LoudnProud General Car Audio Discussion & Questions 9 02-20-2012 11:53 PM
300zx electrical problem Crazycaraudio General Car Audio Discussion & Questions 6 01-29-2012 11:29 AM
Voltmeter issure/Electrical problem? joshua1davison General Car Audio Discussion & Questions 0 09-18-2011 07:52 PM
2001 mazda protege electrical problem, help! Ryan1126 General Automotive Chat 2 05-19-2011 11:10 PM
Need help diagnosing electrical problem. RE_Gawker General Car Audio Discussion & Questions 11 12-04-2009 11:07 AM
