Front loaded horn for 3x2508s - Car Audio Classifieds!
Old 03-02-2012, 10:02 PM
surreal's Avatar
0/11 sssss2489
Default Front loaded horn for 3x2508s
Design request from Area51 here once again, this time for his three soon-to-arrive Digital Designs 2508 woofers.
Kirk will be listening to mostly rock/jazz type of music and prefers a tight punch in his substage. After hours of modeling with these little guys, a seemingly simple front loaded horn was determined to be best fit.
In this case, this FLH will by no means produce the most output possible, but will by all means produce the best balance of sound quality/"punch", output, and response for what he likes in his music.
Fun fact, group delay is rather tight in this design and at its highest point never even reaches 18ms. Many enclosure peak 40-50ms+. Thats horrible! To put it in perspective, thats like listening to your speakers over 15ft away! At low frequency, our ears perceive sound primarily through timing as opposed to intensity (Read: ITD) like higher frequencies. Every bit counts!
Look forward to a build log
Old 03-02-2012, 10:06 PM
0/11 ssssss759
VERY Niceeee sir ... wish i was building this ...lol but the 4-sa8v2 will be fun !!!
Old 03-03-2012, 07:38 PM
area51's Avatar
0/11 ssssss228
I can't wait to build this but I have to build the other one first . Evan, would it hurt performance if I installed a plexiglass window on the front? Should I just put a 3/4" thick plexi instead of the mdf? What would be the best way to show the subs?
Old 03-03-2012, 07:50 PM
0/11 ssssss446
shouldnt make a difference .. but will proly be a lil costly ...
Old 03-03-2012, 10:05 PM
area51's Avatar
0/11 ssssss228
What if I create a window from the back with 1/2" plexi?
Old 03-03-2012, 10:15 PM
Matt3824's Avatar
0/11 sssss3754
I wouldnt do anything that would change the surface of the inside since that peice is what the subs are loading off of. The way I would do it is just cut a hole, put plexi in the hole, then put a trim peice around it on the front that would hold it in place. Then silicone the edges on the inside for a good seal.
Old 03-04-2012, 12:56 PM
surreal's Avatar
0/11 sssss2489
Matt is correct, you may place a window/plexi where every you like - just dont change the inner dimensions/geometry!
Old 03-04-2012, 01:12 PM
area51's Avatar
0/11 ssssss228
Okay, I think I understand. A couple ways I was thinking of tackling this is to mark the whole front wall a sheet of clear 3/4" acrylic plexiglass or cut out a hole just big enough for the subs to be seen then with the router and a rabbet bit create a lip for a 1/2" window sheet of acrylic to seal against.
Old 03-04-2012, 02:01 PM
surreal's Avatar
0/11 sssss2489
would be fine, just do it on the inside of the panel so it is flush and will look better IMO.
Old 03-04-2012, 02:30 PM
area51's Avatar
0/11 ssssss228
Great, I'll do one of those then. Thanks
T-line, 4th order, or Rear Loaded Horn? 813thumper Enclosure Discussion & Design Construction Help 9 11-17-2011 08:11 AM
15 SA 10's in a horn loaded enclouser designed by surreal alvizo913 General Car Audio Discussion & Questions 11 11-06-2011 08:15 PM
Rear loaded horn math.. surreal Enclosure Discussion & Design Construction Help 5 11-08-2010 08:12 PM
Rear-loaded horn jt_buck Enclosure Discussion & Design Construction Help 3 10-31-2010 07:02 PM
Front Loading Horn vs 4th order MisterGrubbs Enclosure Discussion & Design Construction Help 38 09-25-2009 01:58 AM
