Amp acting funny please help - Car Audio Classifieds!
Old 03-03-2012, 09:25 AM
0/11 ssssssss5
Default Amp acting funny please help
I have 1 15'' obsidian sub hooked up to a pioneer 760 amp just some amp from wal mart. When i turn my car on the amp turns on and will run the sub at low volume but as soon as i turn it up to about 10 15 it stops running the sub but the power light on the amp stays on. I've tried to clean my ground, new fuses, and ive checked the remote wire. Can someone please give me some ideas of what to do next?
Old 03-03-2012, 09:28 AM
0/11 ssss31258
edit;
If it's acting funny, you should laugh at it.
but seriously, wire the coils in series and maybe your amp won't shut off.
also, sometimes when you work on a car for a long time, you kill the battery.. if that happened, charge the battery.
nimp360 (03-04-2012)
Old 03-03-2012, 09:35 AM
0/11 ssssssss5
They are already wired in series. Could the amp be stuck in protection mode?
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
it does sound like the subs impedance is too low for the amp,
is it a d4 sub? an the amp should be 2ohm stable?
The Following User Says Thank You to sthrnbumpn For This Useful Post:
Old 03-03-2012, 09:37 AM
0/11 ssssssss5
the amp is only 4ohm stable and the sub is a dual 2 wired up to 4ohm's
Old 03-03-2012, 09:39 AM
sthrnbumpn's Avatar
0/11 sssss2961
well then the next step is get out your dmm
an check voltage at the amp when you turn up the volume
Old 03-03-2012, 09:42 AM
0/11 ssssssss5
could i have ran the amp to hard because yesterday it was working fine and shut off mid song and the power light was flashing
Old 03-03-2012, 09:46 AM
sthrnbumpn's Avatar
0/11 sssss2961
its possible, too much volume an not enough voltage will make an amp cut out,
or poor grounds an connections,
it doesnt hurt to double check the subs ohms an make sure its where it should be,
ive had a tinsel lead short out on me once before an it was running on 1 coil only
Old 03-04-2012, 08:48 AM
0/11 ssssssss5
Got it working it was my fuse holder wasn't allowing enough power to go to the amp
Old 03-04-2012, 08:59 AM
0/11 sssss1364
Feedback Score: 25 reviews
where in michigan are you from?
97 civic ex new build coming soon. head unit poineer premier 80prs fronts/rears diamond audio hex pros mid & high stage amp Diamond Audio HEX 700.4 sub amp diamond audio d6 1500.1 coming sub stage 1 diamond audio d9 15d2 lwire stinger zero gauge & 4 gauge 1 c&d 102ah batts, kenitik 800,200 amp alt mechman
Amps running hot and acting funny - any ideas? Silenkiller General Car Audio Discussion & Questions 18 05-26-2011 05:49 PM
My Ipod's acting funny! gibsonm21 Off Topic Chat 3 04-07-2011 02:09 PM
memphis mcd1000 acting up! help! ben031681 General Car Audio Discussion & Questions 0 12-28-2010 10:26 AM
Car is acting up Help Please! aturcotte127317 General Automotive Chat 13 05-16-2010 05:45 PM
Fedex is acting gbo559 Off Topic Chat 6 08-27-2009 02:44 PM
