aeroport tuning? - Car Audio Classifieds!
Old 03-03-2012, 01:54 PM
0/11 ssssss348
Default aeroport tuning?
Building a box that is 17.6 cubes at 30hz how and what size aeros will i need ?
Old 03-03-2012, 01:56 PM
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
17.6 cubes net after sub and port displacement or 17.6 cubes gross before displacements? How many and what size subs? Are you going for numbers (spl) or loud and low daily?
Old 03-03-2012, 01:59 PM
0/11 ssssss348
it is before displacements.. they are 2 ufo btl 18s and id like it loud and low daily
Old 03-03-2012, 02:03 PM
0/11 sssss1921
a box that is 33 x 33 x 32.25 is 17.66 cubes gross volume with 2 10" aeros 19" long each is 30hz but that is not taking into account any displacements for bracing and subs. and net volume after port displacement is 15.88 cubes
10" aeros would have to be custom made
same box 6 6" aeros 22inch long each is also 15.3 cubes after port displacement and 30hz these would also need to be custom made since psp 6" aeros are 17" usable length max
edit: this is all calculated using torres box calc and the box dimensions are just random numbers i punched in to get your gross volume in the box calc
Old 03-03-2012, 02:07 PM
0/11 sssss1921
So would you rather have more smaller aeros or less larger ones? It is best to go with less larger aeros especially since the 6" aeros you buy at parts-express arent long enough for that low of tuning and you would need them custom made anyway.
Id probably go with 2 10" aeros if you can get some made or make them yourself.
Once you start taking into account sub displacement and bracing and extra baffles displacements it will throw off the tuning so you really need to figure out how much total space after all other displacements before you start figuring the port length in and the volume the ports take up inside the box.
Old 03-03-2012, 03:32 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
Id rather go 3 8" aeros. I dont like torres for aero tuning. And thats a large box for 2 fi 18s lol
Old 03-03-2012, 04:03 PM
0/11 ssssss348
I think displacement of subs are .26 and for the bracing I'm gonna use allthread and idk how much displacement that will be .... And should I go with a 17.6 cu ft box with the aeros or should I go smaller? My old box was 18 cubes ... I want it to be louder any help is much appreciated.
Old 03-03-2012, 04:07 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
what vehicle is this going in?
Old 03-03-2012, 04:52 PM
0/11 ssssss348
Ford probe
Old 03-03-2012, 04:55 PM
zack1442's Avatar
0/11 sssssss77
10inch sono ports at menards, worked good for me
Sent from my PG86100 using Tapatalk
Aeroport Tuning Question.. Rayo187 Enclosure Discussion & Design Construction Help 2 12-29-2011 11:35 PM
45's in an aeroport focusedfornow Enclosure Discussion & Design Construction Help 4 09-22-2011 12:07 PM
Question about Aeroport length & tuning.. RapidAutoQuotes General Car Audio Discussion & Questions 4 02-02-2011 11:00 PM
Aeroport Help Please?!? Pieper Enclosure Discussion & Design Construction Help 6 04-18-2010 05:04 PM
Aeroport question resko1 Enclosure Discussion & Design Construction Help 8 11-19-2009 10:38 PM
