3 Subs, 2 Amps Strapped. Which coils to get? - Car Audio Classifieds!
Old 03-03-2012, 09:38 PM
NoPh33rRaCiNg's Avatar
I <3 ( . )( . )'s
0/11 sssss3010
Feedback Score: 29 reviews
Default 3 Subs, 2 Amps Strapped. Which coils to get?
I'm gonna be doing a build at the end of this year, gonna be 3 subs 15/18's and 2 big amps strapped. Wondering what coils would be best to get, the amps are .5 stable, probably a little bit lower than that. I would like to have each amp seeing around .5 strapped at 1 total. Dual .7's? Dual 1's? Dual 1.4's? Dual 2's?
Confusing myself calculating everything...
Team DC Audio : Team NWSPL : Team Shok
02 Tahoe - (1) 15'' XL, Shok II, Shok 1/0
03 S10 (in progress) - (3) 15'' Lvl5's, (2) DC 5k's, lots of Shok 1/0
Old 03-03-2012, 09:44 PM
Active Member
0/11 ssssss846
Feedback Score: 23 reviews
3 d4s will get u to .66. U could strap each amp at .33 each nominal?
Juicebox Battery Online Operations Manager.
Old 03-03-2012, 09:46 PM
baaudio's Avatar
0/11 ssssss248
if you got dual 2s you could get .67 on each amp. with dual 1.4s i imagine that would put you around .5 or less on each
http://www.mobileinformationlabs.com...iring-1%20.htm using this calculator i put in the resistance then put 1.5 for the speakers. it runs it just fine and accurately it seems
97 Explorer Sport/Dual Alts/Northstar batts/Crossfire woofers/DC Audio amps
Team NWSPL--Team DC Audio
Old 03-03-2012, 09:47 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
id strap at 1.33
Veteran Member
0/11 sssss3359
Actually 3 dual 1.4's could wire to. 93 so each amp would see. 46
Old 03-03-2012, 09:49 PM
Matt3824's Avatar
0/11 sssss3754
D4's would get you .66
D2's would get you .33
D1.4's would get you 1
D.7's would get you .5
I'd go with .7s
Old 03-03-2012, 09:51 PM
I <3 ( . )( . )'s
0/11 sssss3010
I'd go with .7s
You 100% on this? And are these strapped loads or each amp?
Old 03-03-2012, 09:55 PM
baaudio's Avatar
0/11 ssssss248
i get .23 on each amp with 3 .7 ohm coils wired in parallel
Old 03-03-2012, 09:56 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
Subwoofer Wiring Diagrams, Three 1 ohm Dual Voice Coil (DVC) Speakers
Veteran Member
0/11 sssss3359
Well first of all there's multiple ways to wire so giving one answer to every coil is incorrect. I was just giving you the closest to what you wanted. Series, series/parralel, and parralel series will give you different loads.
strapped amps making weird noises from subs treylittlefield (Sundown Audio) 10 02-17-2012 09:18 AM
Clamping strapped Amps Staralpha1 General Car Audio Discussion & Questions 1 10-09-2010 09:47 PM
4 amps.. 2 subs. strapped or an amp for each coil?? I dont get it Vaginatarian General Car Audio Discussion & Questions 19 02-25-2010 05:18 AM
sub wireing with strapped amps csu87 General Car Audio Discussion & Questions 5 09-03-2009 10:05 PM
Quick help needed-gain setting on strapped amps toolmaker (Sundown Audio) 5 08-23-2009 06:31 PM
