Help me get loud? - Car Audio Classifieds!
Old 03-04-2012, 01:00 PM
KTMrida4life's Avatar
0/11 sssss2271
Feedback Score: 33 reviews
Default Help me get loud?
So heres my current setup
3 SA 8s on a SAZ 3k wired to .67. Subs back, port back, slot port 2.25" x 11.25". Box is tuned to 33hz.
It did a 138.5 on the meter 41 hz, which is my peak. 2 months ago when I did this build it was loud at first, now Ive gotten used to it and want way louder.
Heres the box dimensions I have to work with. I will double check these today. These ARE INSIDE THE MDF dimensions.. meaning I have accounted for material thickness with these specs. I will double check these measurements tonight though in my trunk. This also will leave about 4-5" of room between the trunk and the left side of the box for a side firing port. The 12.5" depth does NOT leave room for rear firing subs as I am considering doing sub up port side.
This is roughly 4.5cuft.
This my trunk right now.
With this air space, and trunk.. if I want to get as loud as possible off the same power (SAZ 3k) what is my best option?
Several SAs or some bigazz monster of a sub(s)? 2 beastly 12s or a bunch of SA 10s/8s?
Need help here. I want to do a 145+
Old 03-04-2012, 01:16 PM
0/11 sssssss42
To me the box seem big for 8s. You could do 3 sa-10s in that size box.
Old 03-04-2012, 01:20 PM
0/11 sssss2271
Well I was going to run 6 for max cone area.. something like 300 cubic inches.
But Im not sure which is louder, 6 SA 8s, or say something like.. 2 NS 12" or 2 9512s on the same power. ??
Old 03-04-2012, 01:34 PM
05TRAILBLAZER's Avatar
i ♥ Sundown Audio
0/11 sssss1946
MORE CONE AREA LOUDER TO THE EAR as far as metering who knows mang
Old 03-04-2012, 02:22 PM
0/11 sssss2271
I dont get this either. How could something be louder to your ear, and not louder to a meter?
Old 03-04-2012, 02:23 PM
0/11 sssss1237
generally the guideline is double the woofers or double the power for twice the loudness
Old 03-04-2012, 02:32 PM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
in order to score good on a meter usually u tune high (around 40-50hz, sometimes higher for highest score)
however the ear perceives lower bass as louder.. I personally like around 28hz
2005 Buick LaCrosse
HU: Alpine INE-S920HD
Old 03-04-2012, 02:40 PM
0/11 ssssss816
Feedback Score: 22 reviews
I had good luck with sa-8's in about .4 cu ft net each, with about 12sq in. of port each, tuned to whatever freq you desire. The smaller the enclosure, the more power they will handle.
Old 03-04-2012, 03:19 PM
AllenH427's Avatar
0/11 ssssss841
I replied in another thread. You can do little things, test a lot, change enclosures.. it all comes down to your car. Unfortunately it sounds like you just have a car that the meter doesn't like. There is a reason Blazers and CRX's are common burp machines... they get loud easily (don't hate haters.)
TEAM XS - MECHMAN - FI - AUDIOQUE
152.6 OUTLAW AND CLIMBING
The Following User Says Thank You to AllenH427 For This Useful Post:
05TRAILBLAZER (03-04-2012)
i ♥ Sundown Audio
0/11 sssss1946
idk but i could care less how i meter as long as its loud and sounds good daily!
The Following User Says Thank You to 05TRAILBLAZER For This Useful Post:
peeteeolite (03-04-2012)
Would this be AS loud? milly General Car Audio Discussion & Questions 16 10-04-2011 09:27 PM
How loud can i get? grocerygetter General Car Audio Discussion & Questions 11 07-12-2011 11:31 AM
loud moneybags General Car Audio Discussion & Questions 18 03-18-2011 04:06 PM
how to get loud... 20Hz_And_Below General Car Audio Discussion & Questions 16 02-21-2011 08:14 PM
How to get loud? dadydolas General Car Audio Discussion & Questions 26 02-04-2010 02:18 AM
