Electrical Requirements for 3.0k to 7.5k watts? - Car Audio Classifieds!
Old 03-05-2012, 01:43 AM
Jdubs04ss's Avatar
0/11 sssss1561
Default Electrical Requirements for 3.0k to 7.5k watts?
I have an 04 Impala SS 3.8L that came with the 9c1 125amp alternator that does 65-70amps at idle.
My Current Electrical System Consists of;
PowerBastards 240amp Alt
Optima G34/78 Yellowtop (55ah)
ZZP Stg.1 Volt Booster (+0.6v)
Big 6 (Big 3xDouble runs)
One 18ft Monster 1/0 +Pos
2 Stinger SPV70 (70ah) batteries in trunk
I was able to run my DD M3a (Gain 75%/No Bassboost) @ 1ohm crankin out 3000wrms to 2 15" Memphis CM Mojo and would hold 14.4v-14.9v while crusin at any speed. Full tilt @ Idle would hold 14.1v to 13.6v for about a full minute but after about 90sec on some crucial decaf, it would dip sometimes as low as 12.5v
I then sold 1 SPV70 and was able to run the M3a @2ohm and was similar to 2 batteries at 1ohm but would hold it longer before it dips into the 12's.
Well now I am looking to part ways with my baby but only in search of her older brother M4a which leads me to my question..Obviously what I have right now won't cut it, but If I was able to hold 3k pretty good with 2 Stinger SPV70 (70ah) batteries...tell me what you think about what is going to be my new setup..
Beefin up for the M4a;
DC Power 270xp/320xp alternator
2nd 1/0 + Run (Main to Secondary Batteries)
1st 1/0 - Run (Main to Secondary batteries)
TWO (2) XS Power XP3000 (120ah ea/240ah total)
So do you think a DC Power 270xp or 320xp alternator, 2 XS Power XP3000(120ah) batteries, and 2 extra runs from main to secondary batteries be sufficent enough for an M4a?
Thanks
Sent from my DROID 4 using Tapatalk
2004 Impala SS
240amp Alt,XP3000s,BIG 3,1/0,Alpha Damp
Pioneer AVIC-X940BT
Digital Designs M3a(3 of them) & SAZ-2500d
18" Crossfire XS V.2 / 15" DC XL m2 D2
Need DC 270xp,320xp or bigger alt
Old 03-05-2012, 01:50 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
That's probably right on the edge, but I think you'll be ok. The only way to really know is to get it all in and start beating on it while monitoring voltage.
If you're springing for a new alt anyway, can you afford to keep the one you have and get a dual bracket for the DC? That would be sweet.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
SacTownBully84 (03-05-2012)
Old 03-05-2012, 09:08 AM
2003f150's Avatar
Digital Designs FTW!
0/11 sssss1227
Thanks
What ohm you running the m4a at?? Example I have a buddy that ran a m4a @ .5 ohm with 5 deka 9a31's and stock alt in a pt crusier it would go down into the 11s pretty quick. I would say 4 good xs batts or similiar if you wanna maintain decent voltage and yes a alt helps too. M4a is a little over 2 m3's for reference power wise at full capacity.
4 9918SC,4 DD M4 @ .25 ohm each 6 NSB 90's,2 NSB130's SINGER 350A ALT!!Flat wall....Scores TBD USACI and Db Drag
Old 03-09-2012, 11:48 PM
Jdubs04ss's Avatar
0/11 sssss1561
I would love to keep mine and run a dual alt system but I think my car is one of the most difficult cars to throw a dual alt kit in because I would have to relocate my ignition coil packs elsewhere just to do so..I've heard of one person do it but for the amount of work he said it really isn't worth it lol
Id most likely be running it at 1ohm so since its at 1ohm opposed to your buddies .5ohm it will draw a lot less amps so I might have 3 less batteries but the 2 batts I would have are 120ah XS Power batts each and then either a 240,270 or 320amp alternator and I'm not plannin on crankin it either..I just want an m4a so I can run 4500-5000watts out of it and have it be clean opposed to runnin an m3a tapped out sendin dirty power..so in essence I guess te better question would be to run 4500watts would the big h.o alt plus 240ah worth of XS power batteries
2004 Impala SS
Pioneer AVIC-X940BT
Old 03-10-2012, 12:14 PM
0/11 ssssss181
I have a 04 impala as well. I have a 240amp irragi, i think its 120 at idle. I run a d9 at .5 daily, 2 d3100s and i have no problems as long as car is moving. Once im at idle full tilt it will drop to 12.5 raise rpms and its fine again, also have the zzp voltage booster stage 2. I would get the alt with the most at idle. Two of the xp 3000 sound be plenty if your going to run at 1ohm.
max watts on stock electrical? milly General Car Audio Discussion & Questions 9 10-08-2011 05:53 PM
Electrical upgrades for 400 watts rms? sobe3yourself General Car Audio Discussion & Questions 10 02-16-2011 06:22 PM
Electrical for 4700 watts? Mgcauctions09 General Car Audio Discussion & Questions 9 04-07-2010 06:25 PM
What electrical will i need for 2400 watts? westman995 General Car Audio Discussion & Questions 20 12-29-2009 03:04 PM
What electrical for 8500 watts rms? 87linkin General Car Audio Discussion & Questions 32 09-20-2009 08:02 PM
