Anyone with a Audioque amp please help!!!! - Car Audio Classifieds!
Old 03-05-2012, 11:00 AM
0/11 sssss1117
Default Anyone with a Audioque amp please help!!!!
No actually decaf point out that its not centered at 45hz or any frequency so it actually act like a gain. So i guess its consider a gain, but other amplifier like the audiopipe ap1501d has a bass knob centered at 45hz.
But if this was centered at 45hz, you guys will still say its a gain. When it fact it wouldnt be. But this bass boost on these amp are consider gain because they arent centered at any hz.
So in the long run i was wrong, but no one point out that piece of fact. If it was centered at 45hz, then i will be correct.
Ok.
Shit half of you guys were saying if you set your gain to 50% it wont allow you pass that, so think before you go haywire and talking shit because it has nothing to do with the gain, but it very much act like a gain therefore you are calling it a gain.
Old 03-05-2012, 11:02 AM
badmofo529's Avatar
0/11 sssss3329
mine does it too. it also has a pop when i shut the truck off unless the nob is all the way up.
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 03-05-2012, 03:13 PM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
Ditch the knob... you dont need it, problem solved
TeamGG
Team D.O.A.
Old 03-05-2012, 03:16 PM
Veteran Member
0/11 sssss3359
my bro's popped when you shut it off too. he replaced with a saz4500 and problem gone. i agree with no knob. i never use mine.
The Following User Says Thank You to woofer cooker For This Useful Post:
Boomsday (03-06-2012)
Old 03-05-2012, 07:10 PM
0/11 sssss1117
Mine doesnt pop when it shut off or turn off, but the reason i use the knob is for the clip indicator, and for some song that need the bass adjusted. And also the flubbering isnt very noticeable, unless you really tried to listen for it.
Old 03-05-2012, 07:13 PM
0/11 sssss1117
The only reason i use it is for the clip indicator
Old 03-05-2012, 07:17 PM
0/11 sssss1117
Default audioque bass remote flubbering
Well im a little concern because jesseadkins187 on youtube had a similar problem, but he flubbering was noticeable when music was playing, also he had smoke come out of his amp, and need a new one.
Old 03-05-2012, 07:27 PM
AllenH427's Avatar
0/11 ssssss841
It's the knob, by friend has the same problem. Buy a new knob, they're cheap.
TEAM XS - MECHMAN - FI - AUDIOQUE
152.6 OUTLAW AND CLIMBING
Old 03-05-2012, 07:54 PM
MERQUE's Avatar
0/11 ssssss622
the knobs have audible tone, mine on my apk3500 does, but its very convenient to be able to control only the bass.
Old 03-05-2012, 08:56 PM
Decaf's Avatar
0/11 sssss3460
turn sub level down on headunit, its not that hard
somehow before AQ people did fine without clipping knobs...
TeamGG
Team D.O.A.
Audioque 2200d amp ruffbrian Mono Amplifiers 12 11-22-2011 08:08 PM
How to set up an Audioque Amp Crich03 General Car Audio Discussion & Questions 10 02-19-2011 11:38 AM
audioque amp 4x90 budowens83 Multi-channel Amplifiers 11 09-05-2010 06:01 PM
audioque amp budowens83 Wanting to Buy (WTB) 0 08-17-2010 11:14 AM
Audioque amp ? Gabriel ruiz General Car Audio Discussion & Questions 15 03-16-2010 09:50 PM
